Bad idea?
Discussion in 'Suspension' started by Smoove06, Dec 18, 2017.
  1. Dec 18, 2017 at 9:17 AM
    Smoove06
    Smoove06 [OP] Well-Known Member
    Alex
    North Phoenix
    05 SSM DCSB PreRunner
    Starting From Scratch....again
    Has anyone done this setup before? Is it a bad idea?
    Here is my vision to moderately lift my truck.
    First, the specs:
    2005 DCSB OR Prerunner with TSB leafs. Daily Driver with maybe 2% off road use
    HUB to FENDER Measurements:
    FRONT: D = 20.25", P = 20.5"
    REAR: D = 22.0", P = 22.0"
    The plan:
    Install 2017 OR stock suspension (Which should give me about a 1" lift) along with a 1/2" top plate spacer.
    Leave the rear alone.
    The theoretical results:
    A level lift with maybe a 1/4" rake once everything settles
    What do you guys think?
    Tacomamike mike likes this.
  2. Dec 25, 2017 at 12:21 PM
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    Bad title, but otherwise sounds like the plan should work like you said.
  3. Dec 25, 2017 at 12:26 PM
    0331 Well-Known Member
    Seattle
    16' DCSB TRD OR 6MT
    I have a 2016 trd OR and I added a 1/2 spacer up front just to clear the 285s until I get around to a proper suspension and I have the Cali lean going on right now. It’s not very noticeable but it sags in the rear when the bed has any amount of weight in it. Not sure you would have the same results with the 2nd gens but just FYI
  4. Dec 25, 2017 at 4:10 PM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    :thumbsup: Should be ok
  5. Dec 25, 2017 at 7:22 PM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Should end up something like this...
    https://www.tacomaworld.com/threads...rd-gen-suspension.469754/page-5#post-14331275
  6. Dec 25, 2017 at 8:02 PM
    Tacomamike mike
    Michael
  7. Jan 2, 2018 at 1:18 PM
    Smoove06
    Alex
    North Phoenix
    Thanks guys!
