Bad Injectors
Discussion in '3rd Gen. Tacomas (2016+)' started by iltdi, Mar 26, 2019.
  1. Mar 26, 2019 at 3:06 PM
    iltdi
    iltdi [OP] Active Member
    Mark
    Rockford, IL
    2017 TRD Off Road
    Drove 100 miles to work, mo problems. Leave work in the morning and it's idling rough and I get a check engine light. Take to dealer, after a day of diagnostics, thet say I need two new injectors. They are corroded at the tip. A $2000 repair estimate.
    Never had an issue until now
    71k miles
    I'm pissed
  2. Mar 26, 2019 at 3:08 PM
    Boghog1
    Boghog1 Jack of all trades, master of none.
    Southern, NH
    2019 AC V6 4x4 SR
    that sucks
  3. Mar 26, 2019 at 3:09 PM
    BSFord
    BSFord Well-Known Member
    2018TRDSport4x4
    Dang how does that happen!? What kind of gas do you use?
  4. Mar 26, 2019 at 3:11 PM
    iltdi
    Mark
    Rockford, IL
    2017 TRD Off Road
    Costco and a local chain
  5. Mar 26, 2019 at 3:13 PM
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    A buddy of mine brand new gm had a bad injector at 6k miles. Still didnt fix the problem after replacing one. Had to replace the whole left side of Injectors.
    It happens. You might have gotten bad gas somewhere.
  6. Mar 26, 2019 at 3:13 PM
    BSFord
    2018TRDSport4x4
    I dont know how that matters just figured I'd ask... all gas I thought has additives to keep injectors clean which I would assume helps with corrosion :annoyed: sorry man, I wonder if this is a defect?
  7. Mar 26, 2019 at 3:16 PM
    fiftyxp
    I would find a local mechanic, and maybe get a second opinion also to confirm corrosion, unless you know how.
  8. Mar 26, 2019 at 3:18 PM
    pcledrew
    pcledrew Well-Known Member
    BC
    '17 TRD Sport DCLB
    Not where I live.
    Source: on a first name basis with multiple guys who work at the gasoline (and other products) distribution facility in our region. They also do all the additive / prep before distributing to fuel stations.
    Costco gets, apparently, the worst of 3 recipes.
    AdventureKid likes this.
  9. Mar 26, 2019 at 3:20 PM
    TomTwo
    TomTwo I CAN FIX THAT
    Bill
    Almost Alabama
    2013 TRD Double Cab Sport
    All injectors have a spec to be within for the whole set to work properly or they will cause problems. Sorry to say replace two now and you will be replacing the rest later.
  10. Mar 26, 2019 at 3:20 PM
    Boghog1
    Southern, NH
    2019 AC V6 4x4 SR
    I thought Costco was tier 1 or top tier or something like that?
  11. Mar 26, 2019 at 3:22 PM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    SoCal
    2018 DCSB TRD OR
    Foreman at Toyota told me similar.
    Someone dedicated to only Costco gas in a new Chevy at 35k miles needed some major work done just because of the gas quality.
  12. Mar 26, 2019 at 3:24 PM
    eon_blue
    eon_blue got boost?
    Monrovia, CA
    2004 3.4l TRD 4x4 Tacoma XtraCab w/5 speed
    I've read that some Top Tier stations have gotten in trouble for not sticking to the Top Tier standards...meaning they do what they have to in order to get the Top Tier label but then go back to using poor quality fuel afterwards. I don't know how the system works if they get tested yearly, at random, or what. Just remember reading that somewhere once, for what it's worth
  13. Mar 26, 2019 at 3:25 PM
    iltdi
    Mark
    Rockford, IL
    2017 TRD Off Road
    I use the local chain 80% and Costco the other 20%
  14. Mar 26, 2019 at 3:25 PM
    LivinOnEdge
    SoCal
    2018 DCSB TRD OR
    What's the "Local chain?"
    Not witch hunting, just want to google to find out more about it.
    JaCado and jmneill like this.
  15. Mar 26, 2019 at 3:27 PM
    iltdi
    Mark
    Rockford, IL
    2017 TRD Off Road
    Fas Fuel
    They are a Amaco station
  16. Mar 26, 2019 at 3:30 PM
    LivinOnEdge
    SoCal
    2018 DCSB TRD OR
    Well I know absolutely nothing about IL but heres what I found at least.
    Fass fuel are diesel injector manufacturing? Lol idk....
    Amoco was purchased by BP who's supposedly #1 Top tier by the almighty google. However I wouldn't be surprised that Amoco is getting the cheap stuff so BP stays up top.
  17. Mar 26, 2019 at 3:31 PM
    kodaco771
    kodaco771 Well-Known Member
    So Cal
    2017 OR DCLB 4x4
    6112/5160's & Wheeler's Progressive 3AAL SCS SR8’s
    Would running BK44 through it help prevent it? That stuff seems legit, I used it on my old T100 and it cleared an injector that was missfiring.
  18. Mar 26, 2019 at 3:34 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    What injector is bad? sounds like a direct injector for those costs... man that sucks.
  19. Mar 26, 2019 at 3:35 PM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    I've sent 13b and 7.3 injectors out to be reconditioned and tested and it cost much less than the price of new injectors.
    Big tall dave likes this.
  20. Mar 26, 2019 at 3:45 PM
    iltdi
    Mark
    Rockford, IL
    2017 TRD Off Road
    They are direct injectors, I saw them out and they sent pics to Toyota
