Bad lights in air conditioning console, LED replacement?
Discussion in 'Technical Chat' started by WindCriesReverb, Sep 25, 2008.
  1. Sep 25, 2008 at 11:51 AM
    WindCriesReverb
    WindCriesReverb [OP] Member
    Anaheim, CA
    06 Toyota Tacoma TRD Offroad
    Hey everyone,
    I'm brand new to this forum, in my air conditioning unit, there are 2 light filaments and 2 LEDs, one of the light filaments are burnt out. I wanna replace the 2 light filaments with 2 white LEDs. Does anyone know if there is a schematic for the PCB for this, or the supply voltage to the light filament? I'm wondering if I could simply solder a series resistor to the anode of the LED and to the supply side (assuming its +12V) and the cathode to the ground side (assuming thats the other side of the light filament (2 pins)). Has anyone tried this?
    Thanks in advance guys.
  2. Sep 25, 2008 at 11:54 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I know there was talk about swapping out the led colors, but I haven't heard of replacing the bulbs. When you do it, make sure to take some pictures.
  3. Sep 25, 2008 at 1:24 PM
    WindCriesReverb
    Anaheim, CA
    yeah, replacing the colors would simply require desoldering the existing 2 LEDs and replacing them with new ones, assuming they are of the same voltage. varying voltage LEDs would require changing the series resistors coupled to them. THanks for the reply, I will start measuring voltages on ohming out traces on the board to find out if one side of the light is 12V and the other side is ground.
