Bad luck with vibrations
Discussion in 'Suspension' started by Iluvtacos, Nov 24, 2010.
  1. Nov 24, 2010 at 2:43 PM
    Iluvtacos
    Iluvtacos [OP] Active Member
    Rich
    Rock Hill, SC
    07 trd sport 4x4
    6" procomp lift, grillecraft grille, painted vent shades, 33" procomp extreme AT tires, Moto Metal wheels, Fabtech side steps, Shocker classic train horn, about ten more things which I can't remember
    I have kept pretty quiet and just reading and reading. I deceided to go with a Procomp strut spacer lift because i didn't want to get to invasive wth cutting, welding and grinding etc...... The only snag is the vibration that has ruined all my joy of having a lift on my truck. I have tried various shimms on the carrier bearing and work with BeefedTaco to get ride of the vibration. BeefedTaco knows his shit and produces an awesome product. I have also removed the diff drop spacers and nothing. However, I feel the vibration in my truck stems from the front half of the drivetrain. Why else would it almost go away in 4wd? My next step is to give my truck to my best friend who a master Tech at a toyota dealer whos into rock climbing Toyotas and see what he can do. In the end I feel I will be removing the lift all together but I will have to see what my friend can do. If a solution is found, be certain it will be posted for all who wish to rid their truck of this vibration hell.
  2. Nov 24, 2010 at 3:01 PM
    spamy
    spamy Truck guy
    NorCal
    2017 Tacoma Sport 4x4
    So far the only fix I have seen is a new front diff. Still have a warranty?
  3. Nov 24, 2010 at 5:40 PM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
  4. Nov 24, 2010 at 8:57 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    Is there a tsb on your driveshaft. All my vibs came from my driveshaft, mine was modified but it had a dent in the tail section that connects to the rear end.
  5. Nov 26, 2010 at 8:00 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    if they come from the front try the this
