Bad mileage 2013 taco 4 L 4x4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cliff4x4, Feb 19, 2019.
  1. Feb 19, 2019 at 4:11 PM
    Cliff4x4
    Cliff4x4 [OP] New Member
    2013 Tacoma 4x4 dbl cab
    I have a 2013 Toyota Tacoma double cab long bed four-wheel-drive for the first three years to four years I got great mileage the last year to two years my mileage is gotten really bad tried replacing spark plugs replacing air filters only got a couple miles a gallon back used to be 19 miles a gallon now I’m around 13 miles a gallon need help .
  2. Feb 19, 2019 at 4:34 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Just out of curiosity, have you checked your front wheel bearings? I just went through the same thing with a good friend's Tacoma and that's what we traced it down to. How many miles on it?
  3. Feb 19, 2019 at 4:57 PM
    jedirye
    jedirye Wannabe
    Florida
    2013 Baja Supercharged
    Sub'd
  4. Feb 20, 2019 at 2:30 PM
    Cliff4x4
    Yes I checked my wheelbearings doesn’t seem to be a problem but I appreciate the advice .
  5. Feb 20, 2019 at 3:00 PM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    Are you stock still? Tires recently? I haven't noticed much decline in mileage from new,now at about 60 k miles. I'm stock on 245/75R16 tires. Are you on winter blend gas now? That will take away mpg for sure.
  6. Feb 20, 2019 at 3:04 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    where do you live? Cold weather driving and winter fuel steal about 20% of your fuel economy on a Tacoma...I get 16-17 in the cold winter and 20 in the summer...see my fuelly chart.
  7. Feb 20, 2019 at 4:10 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Have you cleaned your MAF? That’s the first thing I’d do if it hasn’t been cleaned for awhile. A dirty MAF is notorious for decreased mpg and performance.
    But 6 mph less is a lot so I doubt it would be only the MAF. Could be MAF , winter fuel blend and winter. Have you noticed any change in performance?
  8. Feb 21, 2019 at 5:33 AM
    ctcz28
    ctcz28 Well-Known Member
    Texas
    2015 Blue Ribbon Metalic DCSB Prerunner
    The lousy quality government gas we get these days causes a lot of problems. I suspect you may have an issue with dirty fuel injectors and most likely a carbon buildup on the backs of the valves. I'd suggest you find a local shop that offers the BG fuel system service (find a shop on the BG Products website). They temporarily disable the fuel feed from your tank and run the engine on a cleaning solution that cleans up the deposits on the backs of the valves and also the fuel injectors. If your valves are carboned up the carbon will absorb some of the fuel injected into the engine resulting in a lean condition to which the fuel injection control will provide more fuel and thus down goes you fuel mileage. If you don't want to pay for the full service you could try putting a can of BG 44K cleaning solution into your tank and see if that helps, but with a 6 year old vehicle if you've never had a fuel system service you need one, I bet it will make a huge difference. They also clean the throttle body as part of the service (or at least they should). If you do this, let us know what happens.
  9. Feb 21, 2019 at 5:38 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I own a 2013 DCLB V6. I get 14-15 city. Seems normal to me.
