bad mileage help
Discussion in 'Performance and Tuning' started by tisher49, Mar 3, 2011.
  1. Mar 3, 2011 at 7:37 AM
    tisher49
    tisher49 [OP] Well-Known Member
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    K&N Air Filter, Westin Bull Bar with PIAA fog lights, Retrax cover, Alpine Head unit with I-Pod interface, maglite mount, Color matched grill surround w/ Grillcraft mesh
    This past July I put a jardine cat back exhaust on my truck. I wasn't looking for much performance gain but mostly for sound. Surprisingly I found that I got a bit of a mileage boost until recently.
    What I have noticed recently is that the truck feels a like it has less "oomph" at the low to mid range rpms and I have to keep it around 2900 3000 rpms to keep the truck at a constant speed. I started putting in 89 thinking this might help and it seemed to for a while but now it is back to feeling weaker again. The exhaust sound has also seemed to get a little louder. Any ideas what the issue is here? I also have a TRD CAI with an AFE Pro Dry filter. As I recall from last time I was under the truck the exhaust was bolted on not welded. Is it possible that it has loosened up and I need to tighten it and or get it welded? Thanks in advance for any help.
  2. Mar 3, 2011 at 7:50 AM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    Whats your milage, have you changed your plugs, computer throwing any codes, right foot get heavier, driving on snow/ice, tried a different gas station?
  3. Mar 3, 2011 at 7:50 AM
    808matt
    808matt Well-Known Member
    hawaii
    15 crew cab
    exhaust leak
  4. Mar 3, 2011 at 10:26 AM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    mileage is at best 18 highway and depending where I'm at on regular roads any where from 13-16. Haven't changed any plugs, computer isn't throwing any codes, in VA so not much snow/ice driving and I try to use the same gas station every time (but I did move from NY to VA in august, maybe gas composition is different down here?).
    In terms of my foot being heavy, I've noticed that if I accelerate quickly through the lower rpms I seem to get a better avg mpg since I am at the lower rpms for a shorter amount of time. This hypothesis seems correct but please correct me if im wrong.
  5. Mar 3, 2011 at 10:26 AM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    is there a way to check this or do I need to have it welded and then see if I notice a difference?
  6. Mar 3, 2011 at 6:05 PM
    808matt
    hawaii
    15 crew cab
    welding is not needed. just go from the headers and work your way down to the exhaust tip. its not the easiest thing to find but it could be as simple as a gasket replace or tightening a bolt.
  7. Mar 3, 2011 at 6:43 PM
    no mods
    no mods Well-Known Member
    cincinnati
    Some stickers
    Nobody mentioned a dirty MAF
  8. Mar 3, 2011 at 7:14 PM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    and what am I looking for exactly? Just any space that could be leaking exhaust?
  9. Mar 3, 2011 at 7:15 PM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    hmm I remember reading somewhere that they mentioned doing that after installing the TRD CAI and I don't believe I did it then. At almost 60,000 I'm guessing that should be an option I consider. Even if it's not the fix it won't hurt right?
  10. Mar 4, 2011 at 5:47 AM
    no mods
    cincinnati
    Some stickers
    Correct, just be carefull not to damage sensor
    excuse my misspellings, reply sent from my phone.
  11. Mar 4, 2011 at 7:20 PM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    any one got any other ideas? Or maybe someone who has had the same thing happen and found a solution
  12. Mar 5, 2011 at 4:35 AM
    no mods
    cincinnati
    Some stickers
    Clean Maf, change air filter, replace sparkplugs, run injector cleaner, inflate tires and get a more scientific means for monitoring fuel mileage. Not to mention Fuel formulas from winter and summer are always changing too. With out a proper means to record driving habbits and other extranious variables its hard to tell what's going on at ur end.
