Bad Misfire after cleaning engine bay
Discussion in '1st Gen. Tacomas (1995-2004)' started by NOLA ItsNotOva, Jul 7, 2014.
  1. Jul 7, 2014 at 6:14 PM
    NOLA ItsNotOva
    NOLA ItsNotOva [OP] Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Cleaned my engine bay yesterday evening. Didn't use too much water or degreaser and covered the MAF sensor and alternator. Idled a little high after that but over time of running, it idled normal. Got in my truck this morning, started up and ran fine until it got to normal operating temperature. Then it started running very roughly and idled poorly. Had to call my mom to pick me up and bring me to work. Sat near City Park all day. Borrowed grandmother's car to get home and back to work tomorrow. Stopped by to properly lock up my truck and tried starting it to see if anything changed, but it actually ran bad even when cold this time. Went home to get my dad to drive the other car back and brought it home. Immediately ran rough. I made a video of what its doing. Gets worse when you put it in reverse or drive. Here's the video: https://www.youtube.com/watch?v=zEM8t-X4Ulw
    Could it be anything other than spark plugs/coils getting water in them?
  2. Jul 7, 2014 at 7:52 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Hey Brandon. This happened to me recently. If you got an air compressor you can blow some areas dry. Also can leave the hood up and run a fan to circulate. Mine ran bad for almost 4 days! Think mine got around spark plug boots.
  3. Jul 7, 2014 at 8:04 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Can those areas really still be wet even sitting for a whole day plus running the engine to normal temp twice?
  4. Jul 7, 2014 at 8:26 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Check some basics like the oil and trans fluid to make sure no water got in. But other than that it's probably just something that's still damp. I say let it idle for a while in your driveway then take it out for a drive. Might have to deal with the rough idle for a couple days but it's probably the result of some wires getting wet or similar.
  5. Jul 7, 2014 at 8:37 PM
    medic2230
    Murph
    Bama! Roll Tide
    Mine did the same thing but it lasted for a week. Yeah on the 4 cylinder water gets past the boots when they get older and shorts out the plug.
  6. Jul 7, 2014 at 9:13 PM
    SDSam
    SDSam from Dirt bike to Dezert Couch
    San Diego
    00 Tacoma prerunner
    Icon Shocks, BTF front, Deaver f67, 33's on stocks, Fiberwerxs 1pc, TDR S/C, Bed & Eng Caged
    water or condensation under the plug boots, have to remove and whip dry.
  7. Jul 7, 2014 at 9:22 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Water in the spark plugs.
  8. Jul 7, 2014 at 9:24 PM
    Taco47
    Taco47 Well-Known Member
    Norcal
    2016 2TR 5-Speed
    happened to me at a self serve car wash a few weeks back. found water got past the spark plug boots and small amounts of water surrounded the spark plug. rolled up some toilet paper dabbed in the hole. took some time to wick it all out.
  9. Jul 7, 2014 at 10:09 PM
    SDSam
    San Diego
    00 Tacoma prerunner
    A rag wrapped on a long screw driver works better and no chance of leaving paper behind
  10. Jul 9, 2014 at 3:07 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Had a lot of water in the 6 cylinder. Had water in my air filter housing because it wasn't closed all the way apparently. Got the water out of those but now, its misfiring again and the code its showing is showing a misfire in cylinder 2. It will randomly get spark because I can feel the truck accelerate itself when it kicks in
  11. Jul 9, 2014 at 3:23 PM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    Water in the spark plug has got to be the #1 cause of misfires that have COP's. They're suppose to prevent water from getting to the plug but once there they prevent water from evaporating out.
    I've had alot of success using canned air (the stuff used to clean out keyboards) followed by smearing dielectric grease in the boot before reinstalling the COP.
  12. Jul 10, 2014 at 10:24 AM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Took all the plugs out yesterday. #2 had the slightest bit of water in it along with some gook on the plug itself. Cleaned it off and sprayed all the other cylinders with canned air and put everything back. Runs perfectly
  13. Jul 10, 2014 at 10:32 AM
    dispatch55126
    MN
    2004 Xtracab SR5
    Nice, glad it worked.
    In some ways, we've forgotten the basics since everything is now controlled by a computer. Years ago, a misfire would first be addressed by pulling the distributor cap and hosing it down with WD-40. Now that everything used COP's, they've become the weak link.
  14. Jul 10, 2014 at 3:48 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    I'm glad too lol. The spark plug socket got stuck in the cylinder twice and was a bitch to get out. However, after driving home today, I've noticed a vibration in my pedal and shifter. I don't know if this is from the water incident or maybe something different. Maybe tires not being balanced? I mainly feel the vibration when accelerating.
  15. Jul 10, 2014 at 6:49 PM
    Andy.G
    Andy
    Virginia
    Still probably a little moisture somewhere. Mine ran funny for 4-5days putting 100 miles a day on. I blew all mine out with a compressor with moisture trap. Still ran funny for a couple more days after that.lol
  16. Jul 10, 2014 at 6:53 PM
    Madjik_Man
    Colorado Front Range
    You should put some dielectric grease on the spark plug boots.
  17. Jul 11, 2014 at 7:04 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    What does that do?
  18. Jul 11, 2014 at 7:09 PM
    Andy.G
    Andy
    Virginia
    Water and grease don't mix. Grease acts as a shield. lol
  19. Jul 11, 2014 at 7:13 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Ah lol. I guess my lack of sleep lately is getting to me lol.
  20. Jul 11, 2014 at 8:34 PM
    Andy.G
    Andy
    Virginia
    Yeah, catches up eventually.haha
