Bad misfiring 96 2rz
Discussion in '1st Gen. Tacomas (1995-2004)' started by Colten, Apr 28, 2013.
  1. Apr 28, 2013 at 6:52 PM
    Colten
    Colten [OP] New Member
    Colten
    96 Tacoma 2RZ
    I have a 96 Toyota Tacoma. Just recently put new plugs and wires on it and tightened one of the belts (alternator). Check engine light was on and I removed the negative battery cable to get rid of it. Now it is misfiring and basically just floods out. What did I do wrong?
  2. Apr 29, 2013 at 10:46 AM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    you didn't check the code. that will point you in the right direction of the malfunction. all you did was temporarily erase the code. nothing was fixed. read the code to figure out what is wrong. Misfires can be caused by many things, not just bad plugs.
