bad motor, what would you do?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wulf, Sep 30, 2015.
  1. Sep 30, 2015 at 8:53 AM
    Wulf
    Wulf [OP] auto dismantling & hoarding disorder
    rock raisin
    Alright, my 96 with 208k on it has a bad motor and needs a rebuild at the minimum. Pass cylinders are at 125-150 comp and the driver's side looks the same except for one which is 170 due to a coolant leak. That cylinder also has an external leak as well, so I either cracked the head or blew the head gasket. In addition to that, the water pump is also leaking. All said it still runs pretty well but leaks/burns a gallon of coolant in about 3 days.
    I've been quoted anywhere from 2-3k for a rebuild + labor, which is a bit absurd considering the value of the truck is probably around 4-6k.
    Another option is a JDM import motor which would be about $1300 shipped. They have about 60k miles so it would probably be due a timing belt and water pump as well, putting me back in the cost of rebuild territory.
    My other option is to get a high mileage motor from a salvage yard, the lowest of which I could find had 181k on it. I'd be looking at $600-$1000 for a motor that's probably due a timing set and water pump and has unknown history. On the other hand, if I luck out and drop it in as is it could run long enough for me to graduate and have the ability to afford better options
    If I did swap the motor I have access to tools, a garage, and some extra help.
    What would you do? It seems like I'm basically SOL no matter what I do at this point, but I'm a college student and it's my only vehicle. I also just spent about a grand on brakes and wheel bearings all the way around and misc fluids.
  2. Sep 30, 2015 at 9:02 AM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    If you can find a decent engine I would just swap it out for a used one. Try and find one that is not pulled so you can hear it run and compression test it. Do the JDM engines have any warranty or any of the junk yard engines? That should be an influence on where you buy.
    The cost of a new vehicle would exceed the cost of repair. So do you like this vehicle and want to keep it longer, that is the real question. You said you are doing the work yourself so that really helps keep the costs down. Keep in mind a blown engine truck goes for around $500 to $1500 depending on the rest of the condition.
  3. Sep 30, 2015 at 9:12 AM
    Large
    Large Red
    Buy the JDM one off CL, swap it and you can run it for many many years before it needs major service.
  4. Sep 30, 2015 at 9:14 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    I would source a good running engine from a wrecked salvage yard truck. they can be found with around 80-100k miles if you look at 4runners for them, they are the exact same engines but people don't put as many miles on them and then just put it in as-is and when you finish school you can decide if you want to do timing belt water pump kit.
    I think the first thing you should do is pull the heads off and see if the block is ok, if it is you can have your heads tested and checked to see if they can be refinished or if they are trashed, it might just be a simple blown head gasket and nothing is wrong with your engine but with those compression readings im thinking the valves need to be reworked. if it were worn rings you would see oily spark plugs and "some" smoking from tail pipe, usually at first cold start.
  5. Sep 30, 2015 at 9:24 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    assuming by your post that you have a shop do the work for you. if you could do some work yourself then the labor cost alone would reduce it by half.
    why not replace the water pump, have the head checked/replaced, and enjoy many more miles?
    you also do not say whether you have a 6 or 4 cyl so that determines the $$
  6. Sep 30, 2015 at 9:25 AM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    I purchased my 2004 Tacoma 4x4 with a blown engine due to a oil leak that the po ignored. I purchased a complete 69k mile 3.4L out of a totaled 2003 prerunner from a salvage yard in Arizona off of eBay. Total with shipping to me here in Maryland was $1400. I replaced all the maintenance items, bolted it in and I'm a happy camper. I love this truck!
    Soul Surfer likes this.
  7. Sep 30, 2015 at 10:16 AM
    Wulf
    rock raisin
    It is a 3.4l v6.
    I do like the truck and had planned on keeping it indefinitely. I was ultimately planning on getting something more economical for a DD and keeping the truck to build but that may have moved it up.
    I can do the work myself but I have been pulling 60+ hour weeks so that really only leaves me time on the weekends. I have access to a garage/tools/help to do a motor swap, but only on the weekend and I can't leave my truck there long enough to tear it apart and diagnose otherwise.
    Really my best option looks like finding a used motor but I haven't found a single one with less than 160k on it. All the yards here that I've talked to already have them pulled and on the shelf so I couldn't verify how well it runs or do a hot compression test either. Most yards do a 30 day warranty on the motor itself for major damage but will only exchange or offer credit back so I could be SOL there if it doesn't run and they don't have another. OTOH the JDM motor has a 2 year warranty against major failure but I'd have to double check.
  8. Sep 30, 2015 at 11:10 AM
    keakar
    karl
    louisiana
    one caution on jdm motors is as far as I know you have to swap out all the sensors to American sensors so your going to be digging pretty far into things and its not just a simple drop in swap like with an American motor.
    not sure where you are located but this can be an option if you find one near you http://www.car-part.com/index.htm
    and don't forget to check for available 4runner engines too, they are easier to find and "usually" have a lot less miles on them
  9. Sep 30, 2015 at 11:28 AM
    68dave
    Dave
    If you purchase from a salvage yard ask for the donor truck's Vin number and run a carfax to confirm the mileage. That's what I did before purchasing my motor, last mileage recorded at the time of the accident matched what the seller had advertised. The donor truck was totaled shortly before I purchased the engine, not sure if records would still be available if a vehicle was dismantled years prior.
  10. Sep 30, 2015 at 2:56 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    I personally would rebuild. Build it my way.
  11. Sep 30, 2015 at 3:18 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yeah, but like a lot of us it's a $$$$ issue. OP, def. get a leak down test before condemning the whole engine, find out where all the pressures going...
    Fallguy6666 likes this.
  12. Sep 30, 2015 at 8:03 PM
    Wulf
    rock raisin
    We did do a leakdown and I don't remember the numbers but I know they weren't great
  13. Sep 30, 2015 at 10:52 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    your motor isn't bad. just a head is.
    there's always rebuilding the top end yourself. if the driver side head is junk (where the problems would be), and you aren't going to drive it anymore, just take it off and take it to a machine shop to do some tests. if it's not cracked and still resurfaceable, let them do it for a grand total of 270 + cost for new valve seals. then get a haynes manual and put it back together yourself.
    machining is still an option people don't think about because they're intimidated by all the work. it's really not that bad, it just takes time. or you can order just a new head for your taco and swap it right out for like 500. but you'll need a head gasket and intake gaskets.
  14. Sep 30, 2015 at 11:11 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Do not buy a jdm motor
    I just swapped a 04 motor in my 97
  15. Oct 4, 2015 at 11:39 AM
    Wulf
    rock raisin
    Can anyone recommend a good company to buy a JDM motor from?
    All the salvage yard motors in the Denver area (found through car-part) are high mileage and overpriced
  16. Oct 4, 2015 at 2:57 PM
    Wulf
    rock raisin
    hmmmm a timing set and water pump kit is only like $200 from rock auto... maybe i should consider doing the JY motor + timing set instead.
  17. Oct 4, 2015 at 3:14 PM
    keakar
    karl
    louisiana
    DO NOT use aftermarket parts for the timing belt kit, EVERYONE I know who did had something fail withing a year or two and had to redo it all again.
    go oem parts only for this kit. most here have gotten this kit from this guy and have nothing but good things to say about the seller and the kit.
    complete kit with all the required parts plus any other related maint items - http://www.ebay.com/itm/180729034728?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
    a kit with just all the required parts - http://www.ebay.com/itm/190580750996?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
  18. Feb 5, 2016 at 9:25 AM
    Wulf
    rock raisin
    Alright, I'm trying to budget for a JY motor and hopefully get it done with my tax return.
    In addition to the cost of the motor I'm looking at also doing:
    • timing belt kit + assoc. wear items
    • spark plugs
    • plug wires
    • radiator cap
    • coolant
    • upper + lower radiator hoses
    • oil filter + oil
    Is there anything obvious that I'm missing? Anything that I shouldn't bother with?
