bad mpg after new spark plugs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by reece13, Sep 14, 2013.
  1. Sep 14, 2013 at 9:11 AM
    reece13
    reece13 [OP] Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Been a long time since I've been on here. Bought a 2010 Tacoma dcsb sport a while back in great shape. Just hit 38k the other day, so I decided to change out the diff fluids, MT oil, transfercase oil and change out the sparkplugs and air filter. When I pulled the plugs, they were def. the originals (ngk 1 side, denso the otherside!) and of course needed to be changed. My mpg wasn't bad before, but now it absolutely sucks. The new plugs I put in were OEM purchased at the local Toyota dealer. I even checked the gaps to make sure they were correct and made sure they all looked ok before installation. I've changed out these plugs quite a few times on these 2nd gen Tacoma's, so it wasn't too difficult. Anyone else experience this? I believe my mpg's have dropped about 2-3 mpg...:confused:
  2. Sep 14, 2013 at 10:27 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    That doesn't make a whole lot of sense. I can see if you were running the wrong plugs you might see a noticeable difference but you should be seeing better mileage after a tune-up. When you changed the fluids did you put 80W90 in the diffs and t-case or did you use 75W140? Thicker oil causes more drag and would make a difference. Though I doubt it would be 2-3 MPG. Change to heavier tires recently by chance too?
  3. Sep 14, 2013 at 10:28 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    So many things can cause it man. Run a couple more tanks of gas through it... every gas station's gas is different too, maybe you got a bad batch? Things just don't sound right, but maybe one gap was off or you dinked it when you installed it?
  4. Sep 14, 2013 at 11:37 AM
    reece13
    North Carolina
    Yeah its def. weird. I re-checked the tightness/torque on all of the plugs about an hour ago and had 2 that we're a little loose. One thing I didn't think about was that I DID fill up at a different gas station than I normally do last week. Maybe I could've got some crappy gas. I re-torqued all the plugs and topped off the fuel tank at the normal place I get gas. We'll see as the wknd progress, maybe it'll get a little better. Oh, and I did use 80-90 gear oil when I changed the fluids out on diffs and transfercase.
  5. Sep 14, 2013 at 11:45 AM
    Coast2Coast
    Coast2Coast Well-Known Member
    Northern Alberta
    2009 TRDOR
    Black Sand Pearl factory paint - flattened "au natural" by tree branches.
    Subbed to see if it was caused by the fuel :popcorn:
  6. Sep 14, 2013 at 11:46 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    That's weird. My MPG didn't change much (if any) when I changed mine at 31k. I gapped my new plugs (bought at the dealer) at .040. My original were worn to .047 passenger side and .045 on the drivers side when I pulled them. I run only Shell V power 93 octane in mine. Like someone else said, maybe you got a bad batch of fuel. Run a few tanks through it and see if it changes.
  7. Sep 14, 2013 at 12:02 PM
    Azntrutek
    Azntrutek Well-Known Member
    ATL
    08 TRDsport -Towpackage
    2".5 lift, HID head lamp and HID lights, color match tonneau cover and running board.
    After changed to Denso irdium plugs ($9/plug X 6) for my truck i constantly get 15 mpg combine city/hwy. I am not a lead foot by any mean. Have been thinking about going back to Denso $2 coper plugs.
