bad mpg?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2KTacoPr3runn3r, Feb 2, 2011.
  1. Feb 2, 2011 at 12:38 PM
    2KTacoPr3runn3r
    2KTacoPr3runn3r [OP] Well-Known Member
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    Bilstein 5100 adjustables, 2 inch top plate spacer, bilstein 5100 rears and 2 inch blocks. Flowmaster super 10 with dual 4 inch tips.
    i searched and couldnt really find anything but mpg mods. im wondering if my mpgs are bad compared to others. ive got a 2000 prerunner 2.7l on 31" pro comp all terrains. i get 20 to 24 on the freeway at 65-75 mph and it seems like no matter if its 65 or 70 or 75 my rpms dont go any lower than 2400 to high 2500. that doesnt seem right to me. i figured with the 4banger and stock size tires i would be gettin high mpgs. what you guys think?
  2. Feb 2, 2011 at 1:49 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Thats really good compared to my 6 cylinder with 265/75/16. On freeway at 75mph I get 17-18. As far as your RPM concern, that seems normal
  3. Feb 2, 2011 at 1:58 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    okay cus i mean some guys are saying they are gettin better than that with bigger tires
  4. Feb 2, 2011 at 3:34 PM
    mikracer
    mikracer Well-Known Member
    San Luis Obispo, CA
    2009 DCSB | TRD Sport 4x4
    You also have to take into consideration the mileage difference from the factory tire size to your current tire size. If you're running a taller tire, the odometer will read less miles because the outside diameter of your tire travels further than the stock size tire.
  5. Feb 2, 2011 at 4:34 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    im runnin the stock 31x10.5 tire size just in an all terrainr ather than a street tire. and im gettin my mpgs/rpms off my scangauge
  6. Feb 2, 2011 at 5:59 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    I get 11 mpg....
    With 37's BITCHES :D
  7. Feb 2, 2011 at 8:21 PM
    NegroTundra
    Land of Enchantment
    Yeah......when I had 285's (D-Rated) with no shell I'd get 18-21 on freeway. Now with my 265's (E-Rated) and camper shell with rack on top I get lower. Whatever....my 40mpg DD is for gas mileage.
  8. Feb 2, 2011 at 9:11 PM
    NegroTundra
    Land of Enchantment
