Bad mpg
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bmerr222, Mar 13, 2019.
  1. Mar 13, 2019 at 11:26 AM
    #41
    KJP
    KJP Well-Known Member
    Kevin
    2013 Tacoma DCLB
    Elka coilovers, supercharged, 4.56 gears, ARB front and rear, 255/75/17 BFG, other stuff that weighs a lot
    a lot of good suggestions here - I agree 7 MPG is a problem worth exploring. I get 10 pulling my travel trailer at 65. So, what I would do: jack the truck up and find if there are any drag issues on the brakes, check the MAF sensor, didn't catch it but have you checked your air filter?, run it by a code reader to see if anything is tripped but not lighting the CEL, remove your tires and borrow someone else's stock tires and see how the numbers compare (I doubt it's just the tires though, but a process of elimination), replace you O2 sensors. Take it for a long highway ride to see what numbers you get at steady speeds (eliminating the comments on jackrabbit city driving). Once those things are exhausted bring out the wallet and dig deeper, such as engine or tranny issues. Good luck!
  2. Mar 13, 2019 at 11:51 AM
    #42
    b_r_o
    b_r_o Beef jerky time
    Alex
    WA
    2015 DCLB
    Is the check engine light on? Have you scanned it for codes?
    Cats can clog without setting codes. Just about any other sensor failure "should" set some kind of code
    A code reader with access to short/long term fuel trims would be helpful
  3. Mar 13, 2019 at 12:41 PM
    #43
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    V6 6 speed 3” lift w/ 33’s and aftermarket wheels. I get 14ish mpg on winter gas.
    Something is drastically wrong with your vehicle or you drive like a dick
    desertrunner24 likes this.
  4. Mar 13, 2019 at 12:55 PM
    #44
    blackschwartz
    blackschwartz Member
    Blake
    05 TRD Tacoma
    first off your lift, the bigger tires, and you probably didn't rear gear the front and rear differentials. the reason I know this is because I have the same thing.
    What you can do to help is inflate the tires a little higher then you usually would but not enough to cause too much wear in the tires.
    swap out your 3.73 gears in both the front and rear differentials to a 4.56 or better yet 4.88.
    hope this helps!
  5. Mar 13, 2019 at 12:56 PM
    #45
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    o_O
    Newfiebruh and tcjacado like this.
  6. Mar 13, 2019 at 12:57 PM
    #46
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I once has a 1974 Cadillac with a 500 cubic inch engine that got that exact mpg.
    b_r_o likes this.
  7. Mar 13, 2019 at 1:09 PM
    #47
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Dirty MAF?
    b_r_o likes this.
  8. Mar 13, 2019 at 1:10 PM
    #48
    tcjacado
    tcjacado Well-Known Member
    My 71 mustang with the 351 Cleveland got about the same also.;)
    b_r_o likes this.
  9. Mar 13, 2019 at 1:17 PM
    #49
    steveo27
    Pittsburgh
    Even without regearing, the gas mileage shouldn’t be 7mpg. I’m on stock gears and get 14mpg as posted above.
  10. Mar 13, 2019 at 1:41 PM
    #50
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    What he said...
    tcjacado[QUOTED] likes this.
  11. Mar 13, 2019 at 1:43 PM
    #51
    Larzzzz
    Larry
    MA
    Pistons ftw.
    b_r_o and tcjacado[QUOTED] like this.
  12. Mar 13, 2019 at 8:23 PM
    #52
    Bmerr222
    Bmerr222 [OP] Member
    Bryce
    2010 black Tacoma
    4 inch lift,33/12.50r18, muffler delete,etc
    Maf sensor is clean and no lights are on. Have a few things I’m gonna try. Can’t keep driving something that gets 7mpg. thanks everyone for the gel
  13. Mar 13, 2019 at 8:27 PM
    #53
    tcjacado
    Have you done a sea foam treatment
  14. Mar 13, 2019 at 8:31 PM
    #54
    Bmerr222
    Bryce
    2010 black Tacoma
  15. Mar 14, 2019 at 1:14 AM
    #55
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    7mpg something is definitely wrong.
    There are a lot of "I get crappy mileage" posts that are "Pilot Error" but yours has merit. Keep slogging through the troll monkeys posting and somebody will have the answer.
    I'd guess brakes might be part of the problem but if they were dragging enough to cause a 50%+ reduction in mileage I'd think your wheels would catch fire in about 10 miles. :bananadead::bananadead:
    TacomaMike37 likes this.
  16. Mar 14, 2019 at 5:05 AM
    #56
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Other person are you sure you are doing the math correctly when computing MPG ? 7mpg doesnt make sense. Do you have a 2000lbs of concrete in the bed, are you dragging dead bodies, are you sure all 4 wheels are still on the truck? All the other crap people are spewing, MAF, sea foam, blah blah, all a waste of time. You must have something seriously wrong with your truck to get single digits.
    Sprig likes this.
  17. Mar 14, 2019 at 5:20 AM
    #57
    Bmerr222
    Bryce
    2010 black Tacoma
    Yes I’m sure the math is right
  18. Mar 14, 2019 at 6:56 PM
    #58
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    No big gay unicorn sticker weighing it down, right? Hear those things can do a number on a truck.
  19. Mar 14, 2019 at 7:29 PM
    #59
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Wheel bearings, carrier bearing, diff, u-joints? Lots of parts can add drag but not throw codes. Heavy tires and wheels can wear bearings faster.
  20. Mar 14, 2019 at 7:39 PM
    #60
    Frogging
    Frogging Well-Known Member
    DEREK
    ORLANDO, FL
    DCLB 4.0 2wd
    ASV vent visors LED tailgate brake light Weathertech floor mats Wish list:Maxtrac Spindles New leaf pack Extended rear shocks Braided Brake lines Konig countersteer Anodized bronze 285/70/18 tires NST Crank lite pulley setup XTP intake manifold spacer Neoprene seat covers Fiberglass fenders Power sliding rear window 1" Spacers for rear wheels
    E-brake pushed in enough to drag but not enough set on the dash light? yikes thats bad
