Bad mpg
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bmerr222, Mar 13, 2019 at 9:22 AM.
  1. Mar 14, 2019 at 7:29 PM
    #61
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC M5
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, backup camera, intermittent wiper switch
    Wheel bearings, carrier bearing, diff, u-joints? Lots of parts can add drag but not throw codes. Heavy tires and wheels can wear bearings faster.
  2. Mar 14, 2019 at 7:39 PM
    #62
    Frogging
    Frogging Well-Known Member
    DEREK
    ORLANDO, FL
    DCLB 4.0 2wd
    ASV vent visors LED tailgate brake light Weathertech floor mats Wish list:Maxtrac Spindles New leaf pack Extended rear shocks Braided Brake lines Konig countersteer Anodized bronze 285/70/18 tires NST Crank lite pulley setup XTP intake manifold spacer Neoprene seat covers Fiberglass fenders Power sliding rear window 1" Spacers for rear wheels
    E-brake pushed in enough to drag but not enough set on the dash light? yikes thats bad
  3. Mar 14, 2019 at 10:03 PM
    #63
    cleats50
    cleats50 Well-Known Member
    chris
    Tacoma 2007 TRD
    air intake push bar running boards
    7? Are you positive? Not questioning your math but that's absurd.
  4. Mar 14, 2019 at 10:26 PM
    #64
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    How loud is that thing without a muffler?
    I'm guessing something is dragging. Rear drum maybe? They can build a ton of heat and it's not as obvious as a dragging rotor.
  5. Mar 14, 2019 at 10:45 PM
    #65
    Thatnoobguy
    Thatnoobguy <-- baby frog story in "about you"
    Florida
    2017 Tacoma trd off road
    Stock, mbrp 3in catback exhaust. 12 in sub from tacotunes
    2010 4 banger huh? These were known to have the piston return springs go back since it works a bit harder then a 6 cylinder, and with those tires/lift it's working even harder. If not maybe the flux capacitor, those are cheap at napa
  6. Mar 15, 2019 at 12:45 AM
    #66
    beetlevegas
    beetlevegas You are no Vader. You are just a child in a mask!
    JP
    Cypress TX
    2011 silver Tacoma TRD 6 Speed double cab
    stuff
    I have the same setup as u and get about 13-14. I dropped to about 7-8 and I cleaned my air filter and my Throttlebody. Cleaned the opening. It was really dirty. I also can two half tanks with 91 and Lucas fuel injector cleaner. I am back up to 14 mpg. Getting about 250 miles a tank.
  7. Mar 15, 2019 at 6:37 AM
    #67
    Bmerr222
    Bmerr222 [OP] Member
    Wednesday
    Bryce
    2010 black Tacoma
    4 inch lift,33/12.50r18, muffler delete,etc
    I changed wheel barring recently. And it’s a v6 not 4 banger
  8. Mar 15, 2019 at 10:24 AM
    #68
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    GA
    2015 MGM Tacoma TRD
    5100's @0 w/885 and aal.
    are you just driving around in 4wd all the time and you don't know it? I had a 4runner that sometimes would still be in 4wd even when the light went off.
  9. Mar 15, 2019 at 10:29 AM
    #69
    txtr_customs
    txtr_customs Active Member
    Abilene, TX
    2015 4Runner TRD Pro, 2016 Tacoma TRD Off Road
    4Runner, txtrcustoms body lift, 35s, King suspension, custom bumpers by txtrcustoms Tacoma, txtrcustoms body lift, 34s
    wow... i thought my 12-13 was bad.... I wish I had some advice but it looks like everyone else has covered it... including all the sarcastic remarks... good luck
  10. Mar 18, 2019 at 7:14 AM
    #70
    blackschwartz
    blackschwartz Member
    Blake
    05 TRD Tacoma
    I'm getting 13-7 mpg and I replaced the entire suspension and steering system( except steering rack) along with the new 33" tires and 16" rims. So I don't think it's a steering or suspension issue I think it's tires and rims. Each one of my tires weighs 100lbs and I bought 6 due to going crazy off-road. So a total of 600lbs extra. The only thing I didn't replace is the gears. I think it's gears. Based on my truck. If you find something else let me know that way I can get better gas mileage too
  11. Mar 18, 2019 at 11:29 AM
    #71
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    My last fill up was 17.2mpg which was a surprise.
    My wheels/tires weigh 80lbs a piece.
    I’m sure your extra rotational mass has an effective.
  12. Mar 18, 2019 at 12:00 PM
    #72
    Montanahunter
    Montanahunter Well-Known Member
    Zhaun
    Helena Montana
    2009 DC TRD off-road
    OME lift Stealth custom wheels ARB bullbar Allpro Apex sliders Prismo design roof rack.
  13. Mar 18, 2019 at 12:59 PM
    #73
    ToyotaRoamer86
    ToyotaRoamer86 Well-Known Member
    Brandon
    Frisco, CO
    2007 Tacoma TRD Sport
    Fox 2.5 coilover with SPC, AllPro EXPO springs with 2.0 Resi, 285 on factory wheels with SpiderTrax
    My 3" on 285 w/ 6 spped is at 12mpg I live at 10k elevation.
  14. Mar 18, 2019 at 6:34 PM
    #74
    Tomshouse516
    Tomshouse516 Well-Known Member
    Thomas
    Doylestown, PA
    2011 DCSB TXtrd
    3" ToyTec, 265/75 GYDT
    ive been clocking my truck since installing 33x12.5's
    15-17mpg (corrected mileage for tires size) that last three tanks mixed highway and city.
  15. Mar 18, 2019 at 7:11 PM
    #75
    revtune
    revtune Dreaming of a 4.7 Tacoma
    Houston
    2007 tacoma DCLB 2wd v6
    5100’s front and rear front set on top notch with trd sport coils toytec add a leaf with one inch block 17x9 Matte Black Rockstar 2 Wheels 295/70/17 hankook atm AFE Stage 2 si with volant scoop Spc upper control arms Undercover bed cap 4.30 gears
    7 seems extra bad, even for a Manual. Something is definitely happening. I’ve got a 3 inch lift with 295/70/17 AT tires and 4.30 gears. I get 14-16 mpg (rarely 16) I don’t really have any suggestions other than the ones already posted. Maybe it’s time to bite the bullet and find an independent toyota pro in your area.
