Bad needle bearing
Discussion in 'Suspension' started by NBourque, Apr 14, 2018.
  1. Dec 30, 2019 at 7:10 AM
    #61
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Someone makes a diff drop kit. Of course, that lowers the diff closer to the ground and may not work with some aftermarket skid plate options.
    Just spend the $40 and an afternoon and do it right. depending on your area, you might even be able to borrow the removal tool or purchase one second hand from a member who has already done the swap.
    xola3que likes this.
  2. Dec 30, 2019 at 7:14 AM
    #62
    xola3que
    xola3que Well-Known Member
    Long Valley, NJ
    2019 Tacoma Sport
    I did a cheated LRT 3" spacer leveling lift. The kit came with the diff drop kit but it didn't help with the vibs. ECGS bushing is where it is.
  3. Dec 30, 2019 at 7:43 AM
    #63
    PyritePirateBill
    PyritePirateBill Well-Known Member
    Bill
    North Myrtle Beach, SC
    2014 pyrite mica TRD Sport 4x4 AC
    OME 886 Nitrocharger lift, Dakar HD leaf pack, u-bolt flip kit, Bilstein b110 rear shocks, Wheeler's super bumps,18x9 Worx Havoc, 35/12.50/18 Nitto Ridge Grapplers, ENVE Grille with LED lightbar & raptor leds, ditch lights, 6k hid, tinted tails, AtTheHelm bed stiffeners, SOS Concepts rear bumper, Demello baja front bumper, Smittybuilt 9.5k winch, Mobtown weld-on sliders, AllPro IFS & transm. skid, Mobtown transfer case skid, led fogs, led lights in rear bumper, 54" Bulldog hi-lift jack, Razorback shovel & axe on Quickfist mounts, Cobra CB w/Firestik antenna, Yellow wire mod for 4Lo, URD y-pipe, 2.5" custom exhaust w/ Borla muffler, Viair portable air compressor, Kryptek Typhon seat covers, AJT dash knobs
    The tsb fix will be very temporary because the dealership will just replace the needle bearing with another needle bearing. Trust me, trust us all when we say the ecgs bushing will fix it and, according to ecgs, it's a permanent fix.
  4. Dec 30, 2019 at 8:06 PM
    #64
    TacomaBeast67
    TacomaBeast67 Well-Known Member
    Calgary, Alberta
    2017 TRD Sport, Dbl Cab, Manual
    K&N Cold Air Intake, N-Fab Rock Rails, Removeable Steps, BAC Revolver X2 tonneau, 265/70/17, engine bay LED’s, Amber/clear strobes
    I drive a 2017 TRD Sport with 102k on the odometer. Last month installed Bilstein 6112 up front with 1.5” lift. 5100’s back. Noticed that vibration from 50-60km/h. Vibration went away when 4H engaged. Did the research and ordered the bushing from East Coast Gear Supply and watched some YouTube vids on doing the bushing install. Last Saturday I got to it and it took me 4 hours by myself, I wasn’t in a rush. The whole job was completely new to me.
    The whole re and re went very well with no problems. I’m happy to report vibration is gone and the ride is smooth.
    Has anyone ever had to do the passenger side as well? Why is the driver side the issue and most focused on and not the passenger side?
    This is an excellent YouTube to watch to do the job yourself.
    https://youtu.be/sXIfHArtvF8
  5. Dec 30, 2019 at 8:10 PM
    #65
    PyritePirateBill
    Bill
    It's not an issue on the passenger side. It has a different configuration in the way it is made
    TacomaBeast67 likes this.
  6. Dec 30, 2019 at 8:30 PM
    #66
    TacomaBeast67
    Calgary, Alberta
    Oh... one more thing I did after noticing the vibration, I installed the drop kit on the diff. It softened the noise and vibration by half and the bushing took the fix the rest of the way.
  7. Jan 2, 2020 at 7:33 PM
    #67
    Thegadget
    Thegadget New Member
    I picked up a 2008 4wd Tacoma with the wonderful rumbling/vibration in the floor board. This truck is a one owner completely stock. First thing I did was replace both wheel bearings on the front. No change in the noise. I tried to test with the recommendation of engaging 4wd. I am not noticing any difference in the sound, but it was very difficult to tell since I was in a bumpy dirt road. The noise is the loudest at 45-55mph. It is still there, but almost gone at 65-70mph. I am hoping it is the needle bearing. Since the cv axles have a couple cracks/wholes in the boots, I will probably just replace the axles since I will be pulling it out anyway. Does anyone have the puller tool as a loaner in Waco TX area? I would really appreciate it or any suggestions. Thanks again!
  8. Jan 3, 2020 at 7:10 AM
    #68
    CowboyTaco
    North Georgia
    11 TRD Sport
    Hit up the current DFW BS thread. Someone in there should have the tool that they can loan. As long as you don't mind the drive to DFW. Or maybe also post in the TX BS thread. Might find someone closer, but the group in DFW is pretty big, so you'll cast a wide net.
    In fact, I'll tag @Bigdaddy4760 as he seems to have a pretty good pulse on the area and a genuine interest in helping other enthusiasts.
  9. Jan 3, 2020 at 8:48 AM
    #69
    Thegadget
    Thank you! I will look up the DFW BS thread.
  10. Jan 7, 2020 at 4:44 PM
    #70
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    I gots the classic needle bearing vibration which goes away with 4WH engaged. I have an extended travel kit and plan on getting a front locker at some point.
    I was told that installing an ARB front locker will replace the OEM needle bearing? Or do I need to buy the ECGS bearing and install it when the locker is installed? Thanks for clarification and appreciate any information/experience regarding this since I need to address the vibration soon as it is getting louder.
  11. Jan 7, 2020 at 6:15 PM
    #71
    SAPR53
    SAPR53 Well-Known Member
    2019 TRD Offroad
    King 2.5" Ext resi with compress adjust Front and Rear ICON RXT Leafs ICON Tubular Delta Joint UCAs Xenon HD LED Low Beam Swap Baja Sports Wide Cornering Fogs Interior LED AVS In-Channel Extang Solid Fold 2.0 Tonneau
    What did they charge you for labor?
    LeakyAC and htacoj like this.
  12. Jan 8, 2020 at 9:10 AM
    #72
    CowboyTaco
    North Georgia
    11 TRD Sport
    I think the ARB air locker negates the need for the bushing. Since they sell both, you could call ECGS and confirm before placing an order.
  13. Jan 13, 2020 at 3:50 PM
    #73
    NBourque
    NBourque [OP] Well-Known Member
    Nick
    Maine
    ‘21 PRO
    2 hours at $60 an hour.
  14. Jan 13, 2020 at 6:01 PM
    #74
    SAPR53
    2019 TRD Offroad
    Man that’s a lot better than the 250
    I was quoted
    LeakyAC likes this.
  15. Jan 13, 2020 at 6:48 PM
    #75
    NorNev
    NorNev Phone? Call someone who gives a shit.
    Dave
    39° 31′ 6″ N, 119° 59′ 19″ W
    KDMAX Tuned 17 2•2X2•2 Hood Scoop
    A Few
    I did mine on my 17. It's a straight forward repair.
    The bushing is not that much, it's the tool that is expensive.
  16. Jan 14, 2020 at 1:51 AM
    #76
    xola3que
    Long Valley, NJ
    2019 Tacoma Sport
    $60 is the going rate for the bushing? Anyone have a secret shopping place that’s cheaper?
  17. Jan 14, 2020 at 4:18 AM
    #77
    NorNev
    Dave
    A Few
    Their prices may have gone up.
  18. Jan 14, 2020 at 8:01 AM
    #78
    CowboyTaco
    North Georgia
    11 TRD Sport
  19. Jan 15, 2020 at 6:45 PM
    #79
    tacoma oh7
    tacoma oh7 Well-Known Member
    2007 TRD Off Road
    Loosened the nut behind the wheel. ADS mid travel.
    free ground shipping from the above link
  20. Jul 5, 2020 at 4:37 PM
    #80
    K0NPHL1C7
    K0NPHL1C7 Member
    Reading through this thread, it doesn't appear as the original question of "How long can I drive the truck like this" was ever answered.
    I installed the 5100s and I think I notice a slight vibration at 30-40mph(though it may be in my head, it is very faint). I also notice a small shutter when coming to a stop (6speed manual), not sure f that's related.
    Should I expect the symptoms to worsen over time? I do pan on doing the swap, but not sure when. Is delaying it going to lead to bigger issues?
