Bad Needle Bearing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sig45, Dec 5, 2018.
  1. Dec 5, 2018 at 2:53 PM
    Sig45
    Sig45 [OP] Well-Known Member
    Mark
    Maine
    I've been having an intermittent hum/ever so slight vibration on my front driver's side that goes away when 4WD is engaged. Doesn't do it all the time, maybe every 2-3 days. Seems more noticeable around 20-40mph.
    My driver's side front axle/shaft assembly wobbles where it meets the front differential (when I grab it and move it). Passenger side is tight.
    Bad Needle bearing?
    Plain Jane Taco likes this.
  2. Dec 5, 2018 at 2:55 PM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    Yes. If it goes away when you engage 4WD it is the needle bearing. Best fix is to replace it with the ECGS bushing.
  3. Dec 5, 2018 at 2:57 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    If 4wd fixes it, its the needle bearing. If it doesn't its a wheel bearing. Or you get struck by lightning like me, and its both.
  4. Dec 5, 2018 at 2:58 PM
    Sig45
    Mark
    Maine
    Thanks. I had my front Diff replaced less than a year ago. I've already reported this to my dealership (when it started a couple of weeks ago). I'm hoping they'll warranty it.
  5. Dec 5, 2018 at 3:03 PM
    Pigpen
    Dan
    Northwest Montana
    It's under warranty
    Sig45[QUOTED][OP] likes this.
  6. Dec 5, 2018 at 3:03 PM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    They probably will warranty it. But you should see if they will use the ECGS bushing rather than the needle bearing. I have heard of several cases where the replacement needle bearing gives out again. The bushing is rated to last indefinitely (500k miles according to ECGS).
    Gunshot-6A and Sig45[QUOTED][OP] like this.
  7. Dec 5, 2018 at 3:10 PM
    Sig45
    Mark
    Maine
    Would you happen to have a link to the bushing I would need?
    Sorry - not able to look right now.
  8. Dec 5, 2018 at 3:12 PM
    toucan
    toucan Stupid truck
    Sam
    Oregon
    2013 DC offroad MGM. 2012 Super White SR 4x4 RC
    SCS/Bilstein/Icon/JBA/ Relentless/ATH/Smittybilt/Meso/Mobtown/Archive Garage/BAMF/Pioneer/Rockford Fosgate/Sundown/Wet Okole/Spiker Engineering/I'mMr.Yo/RAMMounts/Softopper/Weathertech/Factor55/Morel/DD
  9. Dec 5, 2018 at 3:13 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
  10. Dec 5, 2018 at 3:18 PM
    Sig45
    Mark
    Maine
  11. Dec 5, 2018 at 3:18 PM
    Sig45
    Mark
    Maine
  12. Dec 5, 2018 at 3:27 PM
    Sig45
    Mark
    Maine
    Just double checked my paperwork. Front Differential ($$$) was replaced on 12/29/2107 and since then, I've only put on just over 10K miles. Well within the 12 month/12K mile warranty.
    Is that carrier where the bushing is housed, considered part of the Diff or part of the shaft?
  13. Dec 5, 2018 at 3:32 PM
    outxider
    Sang
    East Bay, CA
    06 DCSB 4x4
    Part of the diff. Its on the driver side where the cv enters.
  14. Dec 5, 2018 at 3:33 PM
    Sig45
    Mark
    Maine
    :yes:
  15. Dec 5, 2018 at 3:33 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    It’s gotta be part of the diff. or there trying to give you the shaft.
  16. Dec 5, 2018 at 3:37 PM
    Sig45
    Mark
    Maine
    Thanks again everyone!
    :fistbump:
  17. Dec 5, 2018 at 3:37 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Are you talking about Toyota's 60/60K warranty?
  18. Dec 5, 2018 at 3:38 PM
    Sig45
    Mark
    Maine
    No - I had my front Diff replaced less than a year ago and less then 12K miles ago.
    Replacement part warranty.
  19. Dec 5, 2018 at 3:48 PM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
  20. Dec 5, 2018 at 4:23 PM
    Sig45
    Mark
    Maine
    Do you mean driver's side?
    "This is for the drivers side ONLY, the passenger side uses a ball bearing"
    racerX969 likes this.
