Bad Needle Bearing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sig45, Dec 5, 2018.
  1. Dec 20, 2018 at 9:41 PM
    #41
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    A question for those who have the ecgs bushing... when pressing it in, do you keep going until it hits a certain stop or is there a specific depth you're supposed to stop at?
  2. Dec 21, 2018 at 3:24 AM
    #42
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
  3. Dec 21, 2018 at 4:18 AM
    #43
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    You're supposed to stop at a certain point, if not, the bushing will contact the spider gear.
  4. Dec 21, 2018 at 10:46 AM
    #44
    Sig45
    Sig45 [OP] Well-Known Member
    Mark
    Maine
    Arrived today!
    4WDTrout, ready6delta and FastEddy59 like this.
  5. Jan 3, 2020 at 5:53 PM
    #45
    SAPR53
    SAPR53 Well-Known Member
    2019 TRD Offroad
    King 2.5" Ext resi with compress adjust Front and Rear ICON RXT Leafs ICON Tubular Delta Joint UCAs Xenon HD LED Low Beam Swap Baja Sports Wide Cornering Fogs Interior LED AVS In-Channel Extang Solid Fold 2.0 Tonneau
    I have a 2019 Offroad on a 2.5in lift, roughly 9k miles and no indications of a needle bearing failure. Is this something that is bound to happen? Does the issue still exist on later years Tacoma’s?
  6. Jan 4, 2020 at 6:12 AM
    #46
    Taco'09
    Taco'09 Well-Known Member
    Yes. Even on stock trucks. Its likely that your truck has the newer version of the needle bearing previously released as a TSB. I have both the old and new and and am not impressed by their newer bearing. IMHO run yours the way it is and if the humming shows up related to the front diff side bearing then replace i with the ECGS bushing.
  7. Jan 4, 2020 at 6:13 AM
    #47
    SAPR53
    2019 TRD Offroad
    ok thanks man, appreciate it. One of the shops local to me quoted 250 for the labor because he said it’s a huge pain in the ass. That seemed really high to me.
  8. Jan 4, 2020 at 6:15 AM
    #48
    Taco'09
    Lots have done it themselves and I have done quite a few but am no pro. Are you comfortable with doing DIY mechanical things?
  9. Jan 6, 2020 at 11:27 AM
    #49
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    It is not that difficult to change- plenty of threads here to see if it's within your ability. The new needle bearing I bought from Toyota 6 months ago appears identical to the OE bearing- same number of rollers in it; I would not expect any different results with it than how long your OE one lasted.
  10. Jan 7, 2020 at 5:51 PM
    #50
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    Dont forget the bearing puller (tool)
  11. Jan 7, 2020 at 6:30 PM
    #51
    Sig45
    Mark
    Maine
    That was over a year ago! :smack:
    :D
  12. Jan 8, 2020 at 12:29 PM
    #52
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    Looks like it's my turn. Our basically stock 2005 Tacoma (~96K miles) has been humming recently and I found a lot of slop in the differential end of the driver's side CV axle. It's our only vehicle right now and I don't have time to tackle it myself. Talked with a local shop this morning and ordered the ECGS bushing.
  13. Jan 8, 2020 at 5:41 PM
    #53
    XSplicer62
    Jefferson State
    Props to ECGS! I ordered the bushing online this morning. The only shipping options were FedEx or UPS, and all were a bit spendy. I added a note that it's OK to send it to my PO Box if they want to. They emailed my order confirmation and changed it to USPS shipping (with tracking number) at a much cheaper price. Excellent customer service!!
    Muddinfun likes this.
