Bad Needle Bearing?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TexasGunGuy88, Sep 12, 2019.
  1. Sep 12, 2019 at 10:26 AM
    TexasGunGuy88
    TexasGunGuy88 [OP] Insta: @midnite_taco
    Burleson , TEXAS
    2017 Tacoma SR5 4x4 SR5sMatter
    6112 / 5160's w/ DAKAR Heavy 285's KO2
    I noticed the leak this morning and took it to the dealer to see if it would be covered. (Driver side)
    They told me that there was too much play in the CV causing the seal to go out. They said the entire differential would need replacement. They then stated that it was not covered due to the lift.
    My question, seeing how it goes into 4wd just fine.. is it possible it’s just a bad needle bearing
    https://youtu.be/Nfj8yNI4JdU
    PvilleJohn likes this.
  2. Sep 12, 2019 at 10:30 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    You don’t need a new diff. You could replace the seal and the solid ECGS bushing for less than $100.
  3. Sep 12, 2019 at 10:33 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Ecgs bushing and a new seal and your good to go. May as well do both sides.
    Dealers avoid replacing the needle bearings because it doesn’t pay them as much as a whole diff would..
  4. Sep 12, 2019 at 5:08 PM
    littlefish
    littlefish Buzz, your girlfriend...
    Hudson Valley NY
    2016 TRD Off-Road DCSB
    The one who dies with the most stuff wins.
    I’m pretty sure the needle bearing is only an issue on the drivers side.
    BlakeM likes this.
  5. Sep 12, 2019 at 5:14 PM
    Empty_Lord
    Dan
    Your correct. My bad.. Toyota just sends us diffs if it’s under warranty anymore.
  6. Sep 12, 2019 at 5:21 PM
    Popojijo
    Popojijo Member
    Washington State
    2017 MGM TRD OR SB
    My 2017 OR looked exactly like that after a lift. Just this last weekend I Installed one of the ECGS bushings and a new seal no more noise or movement as you show on the video. I’m sure you just need to install a bushing and a new seal. Good to go.
    TexasGunGuy88[OP] and whatstcp like this.
  7. Sep 12, 2019 at 6:14 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    That does seem like a lot of play. That could be causing you to have a bad seal and thus oil leak. I don’t think the bushing and a seal will fix this.
    The lift won’t cause this bit even if you replace the seal. The CV movement with just damage the new one.
  8. Sep 12, 2019 at 6:20 PM
    Bishop84
    Bishop84 Well-Known Member
    I would take it to a gear shop for a rebuild, clamshell rebuilds aren't for Diy'ers.
    It probably would have benefited from the ECGS bushing from day 1, I'm surprised you didnt have the vibes from your lift.
  9. Sep 12, 2019 at 7:21 PM
    Popojijo
    Popojijo Member
    Washington State
    2017 MGM TRD OR SB
    If I had a Facebook account I would post a video of mine that is so similar it isn’t funny. I drove around for about two months after the lift before being able to replace the stupid needle bearing with ECGS bushing, Mine wasn’t leaking oil it was just making noises around 40-45 mph flipping it into 4 hi it would stop making growling noises. The consensus on this site is to replace the bearing with a bushing I did and it works great. Hopefully you can pick the right solution and not have to keep revisiting a bad Toyota engineering issue. Good luck
  10. Sep 12, 2019 at 7:30 PM
    Gingerbeard Man
    Gingerbeard Man Well-Known Member
    Jared
    North Dallas
    2016 MGM DCSB Sport 4x4
    Icon stage 3 tubular 285/70/17 Toyo ATII
    I’d just replace it and see what happens. Worst case is you rebuild. Good meeting you tonight.
  11. Sep 12, 2019 at 8:55 PM
    TexasGunGuy88
    Burleson , TEXAS
    You as well thanks for the loaner kit
  12. Sep 13, 2019 at 6:13 PM
    Gingerbeard Man
    Jared
    North Dallas
    Anytime man. Glad I could help.
