Bad news...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Krazie Sj, Sep 20, 2010.
  1. Sep 24, 2010 at 10:48 AM
    #141
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    DO NOT WELD SHOCKS(or NEAR) EVER >>>>>!!!
    Unless you want to kill yourself. Welding generates massive heat that will make them explode :confused:
  2. Sep 24, 2010 at 11:14 AM
    #142
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    We need to start a poll of who actually just cut the nuts off their rear struts.. I did, thats all I know. And I only tried to actually get them off for about 5 min before I realized it was useless.
  3. Sep 24, 2010 at 11:56 AM
    #143
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Take it to a person who knows what they are doing... LOL I had to
    That nut is fucked. Use sawzall and sawzall it off, easiest way!
  4. Sep 24, 2010 at 8:00 PM
    #144
    Krazie Sj
    Krazie Sj [OP] Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Good to know I'm not the only person with this issue.
  5. Sep 25, 2010 at 6:38 PM
    #145
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    any update for today?
  6. Sep 25, 2010 at 7:06 PM
    #146
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Nope, going to the auto store tomorrow or the next day to pick up some nut splitters.
    Driving 45mph over rail road tracks with the nut half loose didn't do anything.
  7. Sep 25, 2010 at 7:15 PM
    #147
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Translated this means
    Krazie will be picking up the wife and she is going too split some nuts for messing with the truck
  8. Sep 25, 2010 at 7:29 PM
    #148
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    It's my truck, I can do as I please.
    However I have been handed my ass over much more trivial crap.
  9. Sep 26, 2010 at 4:16 AM
    #149
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    as long as your wifey says ok first
  10. Sep 26, 2010 at 5:34 AM
    #150
    DSully72
    DSully72 2WD Problems
    Daniel
    Appling, GA
    04 PreRunner TRD Off Road
    If you kill it, can I have your Toyota emblem with the horns? =D hah jk jk. have faith in ur baby!
  11. Sep 26, 2010 at 6:22 AM
    #151
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    I haven't read this whole post, but here's a trick that is simple and effective for getting the top nut off of shocks. I used to do this at the first sign of the shock piston spinning, but it can be done later, even if the nut is badly stripped (ahem).
    Put a deepwell socket onto the nut with a long extension bar on the socket.
    NOTE that the socket does not need to be the original size, if you have stripped the nut, you may need to hammer a smaller size onto the nut.
    Put a ratchet wrench onto the extension bar.
    Make sure the socket is as tight as possible on the nut, it's ok to hammer it on there a bit to get it tight.
    Now for the trick...using the ratchet only for stability, push or pull the whole extension bar-socket assembly to BEND the shock piston.
    You need only to make sure it is bending BELOW the nut and not above it, this is the reason to make sure the socket is firmly hammered onto the nut.
    When you have it bent as far as space will allow, bend it back the other way as far as possible.
    Repeat this a very few times, and the piston will snap nicely off below the nut.
    Done.
  12. Sep 26, 2010 at 6:37 AM
    #152
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Interesting aproach....What do you do if it breaks under the bottom washer holding the assembly to the frame mount?
  13. Sep 26, 2010 at 7:01 AM
    #153
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    How did I miss this?
    Why has this shock not been cut off already?
    WHy is Krazie allowed touch tools?
    Has MJP2 been brought in for jackstand consultation?
  14. Sep 26, 2010 at 7:23 AM
    #154
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  15. Sep 26, 2010 at 8:21 AM
    #155
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    MJP can not be brought in at this stage. Given the "Krazie" timeline, Mike has about 14 more months before this "build" is ready even for jack stands. Krazie is still working on the 1 bolt, on 1 shock. And its been a week. Mike has PLENTY of time to prepare for jack stnd consultation.
  16. Sep 26, 2010 at 8:22 AM
    #156
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    Krazie - any update on the nut that won't bust free?
    At this point the best bet is probably to split it with the tools you recently acquired. Other than that I have seen a hammer and chisel work when applied at an angle to force the nut to start turning - kinda like a poor man's impact wrench. It is hell on the nut/bolt - but it works. Besides, at this point your wife as to know something is up right?
  17. Sep 26, 2010 at 8:24 AM
    #157
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    For some reason, I think he is threatening his truck with a Boner Punch about now....
  18. Sep 26, 2010 at 8:37 AM
    #158
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    That was a give-in. I didn't realize it needed to be voiced.
    What if my truck is a female. Could explain why it's so finicky to my touch.
  19. Sep 26, 2010 at 8:40 AM
    #159
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    maybe you should try threatening the nut. Take a random nut, set it within viewing distance of the stuck one, and beat it with a hammer......
  20. Sep 26, 2010 at 8:46 AM
    #160
    tx_shooter
    Wow... your suggesting a torture tactic? Maybe he could try waterboarding next... lol. I say its time for the sawzall. OFF WITH ITS HEAD!
