Bad oil after 3k miles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rpkean, Mar 26, 2018.
  1. Mar 27, 2018 at 7:49 AM
    #41
    Ridgeline001
    Ridgeline001 Well-Known Member
    Oregon
    2014 DCLB Sport 4wd
    I change at 5k for everything except my 65 Chevelle (3k), and 4 wheeler. Something that does surprise me is the oil in my 96 with 340k miles is cleaner than the 14 with 50k.
  2. Mar 27, 2018 at 7:55 AM
    #42
    Hennessy
    Hennessy Well-Known Member
    Charlotte NC
    13 Red DC TRD Sport
    Demello Baja bumper, Mcneil Fiberglass, Fabtech Uniball Upper Control Arms, Emu Dakar leaf springs, Fox 2.5 Factory Series Coil-over IFP, Fox 2.0 Performance Series IFP
    oddly enough the "quick lube" place I go to, told me a couple times that my oil was fine and it did not need changing and sent me on my way no charge, I think it changes from place to place...
    I have been using synthetic since the toyocare ran out.
  3. Mar 27, 2018 at 8:00 AM
    #43
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I still dont understand how ANYONE can tell if oil is good or bad just by looking at it.
    Color tells you shit. Only a lab test will reveal the truth.
  4. Mar 27, 2018 at 9:06 AM
    #44
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    https://www.nbclosangeles.com/news/local/flushservices.html
    Just some reading about engine flushes by these quick lube places. I hope you actually didn’t get it done.
    In short it does more harm than good. Engines and technology has come so far these vehicles are meant to go for 200k miles and more with just regular maintenance according to your manual.
  5. Mar 27, 2018 at 4:57 PM
    #45
    rpkean
    rpkean [OP] Well-Known Member
    Macomb, MI
    TRD Supercharger
    I read one post in this thread regarding the milky/frothy foam look from the oil filler cap. The oil tech showed me this and assured there is moisture in the oil hence strongly suggested the “oil flush” to avoid damage to the engine.
    I will say my work is about 6 miles away, so I actually do a handful of short trips. That being said, the engine is always warm by the time I get to work.
    Also, I did see the oil from what he had on his hand in a sample...it was back; that’s why I don’t trust whatever garbage they put in there.
    I just got back from the store buying 7qts of 0w-20 Mobil 1 for the wife’s highlander; this event has provoked me to start doing my oil changes next. Also I’m reading the Highlander oil change is typically $80-100 at the dealer since it’s 6-7 quarts fill synthetic.
    I only put about 3k per year on my challenger, so that will be up after the Highlander and I’m considering putting in the one year formula in that vehicle.
    Thanks all for the advice, I just need to do it on my own.
    YouTube is a wonderful thing.
    Hawco636 likes this.
  6. Mar 27, 2018 at 5:15 PM
    #46
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Once you get comfortable doing it yourself (It's easy), look into the fumoto drain valve. They are the shit!
  7. Mar 28, 2018 at 5:51 AM
    #47
    Hawco636
    Hawco636 Great White North
    2010 MGM SR5 - V6 Manual
    If you haven't burnt any bridges yet at the quick lube place, try to get what the engine flush is in writing. Unless of course they just performed two oil changes back to back (flushing), then I would be curious what they did to my engine.
  8. Mar 28, 2018 at 5:58 AM
    #48
    TacomaMike37
    13' DCLB MGM
    Hooked it up to a machine that pumps a cleaner type fluid through the engine.
    What I dont understand is this: Oil does a hell of a job cleaning our engines. It's designed to do this, so why have some tech pump God knows what through the block?!?
    THis story is another example of how the world in general tries it best to take our money any which way it can. Either through lies or scare tactics, or both.
  9. Mar 28, 2018 at 7:41 AM
    #49
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    09 taco has had this milky froth since first oil change in cooler weather
    why? because the moisture from the burnt fuel leaks past the ring gap into the engine internals and condenses on the cold oil cap
    My 1995 F350 does the same thing with its extended filler neck
  10. Mar 28, 2018 at 7:43 AM
    #50
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Get the 12$ engine flush in writing!?:rofl:
    What does that even mean?
    PackCon likes this.
  11. Mar 28, 2018 at 7:44 AM
    #51
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    next hes going to try to sell you seafoam
    TacomaMike37 likes this.
  12. Mar 28, 2018 at 7:48 AM
    #52
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    also its a good idea to get the blinker fluid flushed,it keeps the lights working to full capacity
    rpkean[OP] likes this.
  13. Mar 28, 2018 at 11:13 AM
    #53
    Hawco636
    Quite simple really, if you can think. Ask them what they did to flush the engine, and get them to provide it on paper. Either in a quote format or in a receipt of work already performed.
    One reason behind doing this is to have proof (paper copy) of work performed on his vehicle should anything arise later on down the road. It's called creating a paper trail. Up until this post I have never heard of an 'engine flush' so to be honest I had no idea it was a thing (I do my own oil changes)
    If the op is not worried, then that's why I said an optional step.
  14. Mar 28, 2018 at 11:15 AM
    #54
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Dude I'm being sarcastic, it's 12 dollars
  15. Mar 28, 2018 at 11:30 AM
    #55
    grizquad
    grizquad Well-Known Member
    Massachusetts
    12 Tacoma TRD sport
    Plasmaglow Firestorm lights, Westin Bull bar, Flyzeye interior console lights
    First mistake was going to ANY quick lube. Most of the kids they have don't care and the managers are rated on how many "extra services" they sell. Don't know what you paid there, but I don't do my oil any more and watch for coupons from any Toyota dealer in my area as they have different coupons, and pay about $29. for a Toyota oil change and parts, plus get a free wash! I change mine every 5k. When I had a Dodge with a Cummins in it, I used Amzoil with their extra filter and changed about once a year with Blackstone oil analysis, engine would have lasted another 10 years, but truck rusted from bottom.......
  16. Mar 28, 2018 at 12:19 PM
    #56
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Oil looking bad?
    If the oil is coming out of the drain plug in chunks or it looks milky you have a problem. Color is not an indication of bad oil.
  17. Mar 28, 2018 at 12:23 PM
    #57
    TacomaMike37
    13' DCLB MGM
    The flush was only $12 bucks? Even that amount seems fishy!
    b_r_o[QUOTED] and Hawco636 like this.
