Bad oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Big AL 2014, Oct 30, 2015.
  1. Oct 31, 2015 at 12:43 PM
    #41
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    A more untrue statement has yet to be made on TW. Smoke merely means oil was heated close to flash point and that happens when the oil comes out of the loose filter and sprays on the manifolds. Under law you can not sue for potential damage, only actual damage. It would be the responsibility of the OP to pay to have the entire engine torn down to the block and inspected. It would then be determined if the wear matches the mileage. If its determined the wear does not exceed mileage the OP just lost 2 grand for that inspection. Hardly worth it for the highly unlikely cance that damage was done since emptying the oil pan through the oil filter would take a long time.
  2. Nov 1, 2015 at 5:10 PM
    #42
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    next time quote the whole thing
    I said 'unless something something manifolds'
    sheszh
  3. Nov 1, 2015 at 5:17 PM
    #43
    Pigpen
    Dan
    Northwest Montana
