Bad paint jobs!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hami252, Mar 19, 2013.
  1. Mar 23, 2013 at 7:06 PM
    BamaToy1997
    Bill
    Navarre, FL
    I am guessing that either I am not explaining myself enough, or you are just not understanding what I am saying. True a single stage paint does not have an official clear coat sprayed on the top of the pigment. So it does not have a "Clear coat" directly applied. HOWEVER, since the chemicals that comprise the protective clear finish are mixed in with the pigment itself, and applied in a "single stage" when it chemically dries and bonds, there is a film of the clear finish that resides on the top. That is what creates the gloss finish. Since the chemical compound is essentially the same, it does have a clear coat that is on the top of the finish once it dries. But yes, I can see how when they explain it as not having a traditional "clear coat" it may seem like it is just the paint itself. Again, paint does not require a hardener to dry. If you spray paint on a surface, it will dry just fine. However it will not shine. When you have single stage paint, a hardener is required to be added. If you were to spray single stage paint without the hardener, you would end up with a pasty, mollasis type coating that would never dry. The hardener is needed because of the chemical compound that is mixed in with the pigment, that creates the gloss. I guess in a technical standpoint, we are both right, in what we have learned.
  2. Mar 23, 2013 at 7:09 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    I"m with ya on this one Bama
  3. Mar 23, 2013 at 7:15 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Alright guys whip your dicks out and see whos is bigger so we can end the debate.
  4. Mar 23, 2013 at 10:26 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    We are saying the same thing in a way. I understand what you are saying exactly. The difference is what we are calling it. A Clear Coat or Mixed in is the way I see it. The biggest difference is the single stage will oxidize much faster than a Clear Coated one.
    I'm all good. Hope I didn't offend.
  5. Mar 23, 2013 at 10:34 PM
    nucktaco
    nucktaco Well-Known Member
    Scott
    south surrey, bc
    08 Double Cab TRD Sport
    satoshi mod, sliders, tinted tails/3rd brake, 3" lift,
    You never know the truck could have been damaged during transport from factory to the dealership/holding yard.
  6. Mar 25, 2013 at 11:13 AM
    BamaToy1997
    Bill
    Navarre, FL
    No offense at all taken. Yeah, just in the way we were trying to explain it. Unfortunately yes, the white does oxidize a lot faster. Never was a fan of single stage.
