Bad pinion bearing?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Weevie, Jun 10, 2025.
  1. Jun 10, 2025 at 11:04 PM
    Weevie
    Weevie [OP] New Member
    2018 Tacoma SR5
    Baja suspension, air lockers, in hood air compressor
    I have a 2018 tacoma (SR5) and have been noticing a clunk when I shift into drive and when driving. It currently has 171k. The drive shaft has around 1/4 to 1/2 in rotational play and 1/8 inch or less up and down at the rear differential. I have heard no whining or grinding sounds from the rear differential. Most of the forums say I would hear a whining sound if it was the pinion bearing. Is my rear differential going out? Is it the pinion bearing? Is all of this my paranoia of my truck dying?
    Any help is appreciated!
    Edit: it appears to be less and 1/8 inch of play and the pinion seal is not leaking.
  2. Jun 11, 2025 at 3:51 AM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    Have you driven through any deep water? Check your u-joints.
  3. Jun 11, 2025 at 12:42 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    I see "air lockers" on your profile...
    Wondering if this could be the pinion nut having come loose, assuming a regear was also part of it.
    Have you noticed any noises or oddities when backing up?
    Chew likes this.
  4. Jun 11, 2025 at 1:31 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    good catch, always look first, where the human was last
    4x4junkie[QUOTED] and BillF1564 like this.
  5. Jun 12, 2025 at 11:22 AM
    Weevie
    2018 Tacoma SR5
    There is a solid chance it is just a loose pinion nut. It was re-geared around 120k I believe. I also have not been driving in any deep water (I am way too timid) and I have only noticed a clunk when shifting into drive or reverse (and sometimes when driving from a stop) but no grinding or screeching sounds.
  6. Jun 12, 2025 at 12:30 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    When you say rotational play you mean 1/4-1/2 of an inch?
  7. Jun 12, 2025 at 12:38 PM
    4x4junkie
    So Calif. (SFV)
    I'd suggest discontinue driving it and have it looked at before something really goes wrong with it (not sure if you still have any warranties with the shop that did it, but maybe have them look at it if they're still around). Hopefully it's just that (a loose nut lol) and it can be retightened (perhaps they just forgot to stake the nut).
