Bad rainstorm dead battery.
Discussion in 'Technical Chat' started by kdawg, Oct 22, 2007.
  1. Oct 22, 2007 at 7:55 AM
    kdawg
    kdawg [OP] New Member
    99 Plainjane Tacoma Manual 2WD
    We had a bad rainstorm on Friday night and the truck got pretty wet. Made it home OK but when I went to start the truck the next morning the battery was dead. Thinking the engine was soaked I let it sit in the sun a few hours to dry out and it started without a jump but just barely. Ran fine the next day but the idle was rough. Woke up this morning and battery was dead again this time I had to jump it. Started up quick with the jump. And diagnoses as to what is going on? I'd say I got water in my distributer but it doesn't have one. Anyone? Did my batter just happen to die at the same time as the rainstorm?
  2. Oct 22, 2007 at 8:07 AM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    i think it is just the battery
  3. Oct 22, 2007 at 8:21 AM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    If your battery is 5 years plus, I might say its your battery. But then, you could be your alternator too, not charging the battery.
  4. Oct 22, 2007 at 8:26 AM
    kdawg
    Could the alternator just be wet or did it get ruined from the rain? It's been three days now. I've driven it quite a bit so I would think it would have dried out by now.
  5. Oct 22, 2007 at 8:34 AM
    2003greenbean
    socaste,sc
    03 trd
    go to a parts store have them tested the do it for free
  6. Oct 22, 2007 at 8:40 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I'm leaning towards the battery. You might have a heavily corroded connection to your battery that would be causing some problems. Unscrew the leads and check to see how clean they are.
    I have found that high humidity seems to cause either the battery or alternator to go out on my Saturns. I don't see why a Toyota would be any different, aside from Saturns being pieces of crap.
  7. Oct 22, 2007 at 8:53 AM
    kdawg
    When you say "Go out" do you mean like no good anymore? Or just not work when humid?
  8. Oct 22, 2007 at 9:07 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    They pack their bags and move into the dumpster.
  9. Oct 22, 2007 at 9:11 AM
    kdawg
    Damn! Whats the best way to check the alternator?
  10. Oct 22, 2007 at 9:21 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    Go to AutoZone and ask them to check it. They can measure the output amperage.
    I could be wrong on this, but I think that alternators are all or nothing. In other words, they don't partially work. If you have been driving around, then your alternator is working.
    I still say, check your connections. If the battery posts are corroded, the AutoZone battery test will give you some screwy results.
