Bad Rear Diff, Clutch Pedal Assembly at 5k
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Metal Toy, Oct 11, 2019.
  1. Oct 11, 2019 at 6:57 PM
    Metal Toy
    Metal Toy [OP] Well-Known Member
    2021 2.7L AC 4x4
    Interesting day at the dealership. I brought my truck in for a noisy clutch pedal and a howl at highway speeds. I test drove the vehicle with a technician and duplicated the discrepancies. Surprisingly, they are changing the clutch assembly including the master cylinder and the rear differential. With only 5k on the truck hopefully, this is the last of its issues. Anyone else had a rear differential replaced this soon?
  2. Oct 11, 2019 at 8:49 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    I had the gasket replaced on mine and I think it's possibly weeping again. Doesn't concern me though at this time. There have been other members that have had their rear diffs replaced and turns out the noise is completely harmless according to Toyota.
  3. Oct 11, 2019 at 8:51 PM
    Bishop84
    Bishop84 Well-Known Member
  4. Oct 11, 2019 at 9:02 PM
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    I wonder if yours was undefiled. Mine was by over 25%. It is also weeping/sweating in few places. I showed it to my friend who used to be a master mechanic at Toyota (now owns his shop), he said it was nothing to worry about. I may re-torque the bolts at some point. Have them check the fluid in the front differential too, mine was 30% low from the factory.
    Metal Toy[OP] likes this.
  5. Oct 11, 2019 at 9:46 PM
    Metal Toy
    2021 2.7L AC 4x4
    I have read that usually the howling noise is considered normal or harmless. However, if it normal or harmless I question why there has not been a resolution implemented to stop the noise from occurring. Regardless of its flaws, I am still happy with my truck. Is there such thing as a perfect 3rd gen Tacoma out there :)?
  6. Oct 11, 2019 at 9:48 PM
    Metal Toy
    2021 2.7L AC 4x4
    Thanks for the heads up. I will have them check the front diff as well :thumbsup:.
  7. Oct 11, 2019 at 10:03 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Its a harmonic resonance, they do have a TSB for it.
    ryan760 likes this.
  8. Oct 12, 2019 at 4:32 AM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    Both common problems that will likely reoccur by installing the same parts.
    I use a tube of white lithium grease on the clutch spring pivot points and rod pivot every so often, and silicone grease on the master cylinder rubber boot. Keeps the clutch super smooth and quiet. I'm planning to do this every oil change from now on.
    MtnFisher and ryan760 like this.
  9. Oct 12, 2019 at 4:45 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Yeah no shit.
    Specifically - what was wrong with the clutch? Just noisy when actuating the pedal?
  10. Oct 12, 2019 at 6:50 AM
    shakerhood
    Southern Ohio
    White Lithium and silicone greases will usually melt away and the noise will return, try using High Temperature Disc Brake Grease instead.
    MtnFisher, tonered and Pablo8 like this.
  11. Oct 12, 2019 at 7:50 AM
    ryan760
    ryan760 Well-Known Member
    Not to rain on your parade but the diffs don't start making noise until after a few hundred to a few thousand miles. It's a normal, albeit annoying noise. Nothing to be concerned with from a driving/longevity/safety point of view, just a quirk of these trucks. It will likely reemerge at some point down the line, so don't be too alarmed.
    shakerhood likes this.
  12. Oct 12, 2019 at 7:55 AM
    ryan760
    Because if Toyota has deemed it "normal/harmless" then it doesn't make much business sense to spend millions of dollars on a redesign that might annoy a small fraction of owners. All of these trucks in stock form have the noise, just that some people are more aware of it/annoyed by it than others. If I hadn't of joined this forum, I probably would have never noticed it.
    The only reason I believe Toyota here is because a faulty diff that could fail early would be massive liability for them. We would have also seen many cases of seized diffs/rollovers/accidents by now given that these diffs have been howling since 2015 and some people have well over 150k miles on their 3rd gens.
