Bad rear end bearings, need help.
Discussion in 'Technical Chat' started by Tacoma12, Jan 18, 2020.
  1. Jan 18, 2020 at 2:36 AM
    Tacoma12
    Tacoma12 [OP] Well-Known Member
    Clint
    Mid Michigan
    2012 Tacoma 4x4 dbl cab LB
    stock
    Im only asking because im sure im paying.
    My son is at school and has a 2011 Tacoma 4x4 4.0 v6 with 180,000 mines on it.
    Has a howl in the rear end, we thought carrier bearing so pulled and replaced that but upon investigation sounds like pinion bearing or more is bad within the rear end housing.
    So my question is, pull and replace what's needed in the rear end OR buy a complete rebuilt rear and replace the whole unit.
    He does not have lots of time to waste and it's his only vehicle, I have never worked on the rear end of a Tacoma.
    So would the assembly be the way to go, if you have done this kind of job what ya think?
  2. Jan 18, 2020 at 2:04 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If time is a factor buy a rebuilt differential not the whole axle housing
    out and in a easy day a few hours keeping at things
    I am guessing you can do the gear set up if your repairing yours thing is your looking at a few days most likely to get the parts you need .
    Just curious where the carrier bearings you replaced bad ?? Did you not check the pinon bearing when setting things up
    Then I had differentials scream for years
  3. Jan 18, 2020 at 6:06 PM
    Tacoma12
    Clint
    Mid Michigan
    stock
    Carrier was bad and replaced. Rear howls pretty bad. If you put a screwdriver to the housing and listen at the other end she screams pretty good. Didn't sound good.
  4. Jan 18, 2020 at 6:08 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Rear howls bad when driving? Id be afraid the rear diff might be on its way out...have you checked the gear oil in it recently? Maybe do a drain and fill and see what comes out, hopefully no metal pieces but it could explain the howl if so. Or if it's been running while low on gear oil
  5. Jan 18, 2020 at 6:08 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Yeah just replace the 3rd member and move on. Easy day. Can find one from 1st gens and 1st gen tundras and ofcourse 2ndgens.
  6. Jan 18, 2020 at 6:09 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Sure its not Ujoints
  7. Jan 19, 2020 at 3:17 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    If the carrier bearings were bad did that impact the meshing of the gears enough to now cause your screaming??
    Even with your best efforts to adjust the pattern of the gears meshing .
    Did the noise start on the test drive or a few trips later ?
    At this point a rebuilt differential might be the fastest and best option .
