Bad sensors and seals
Discussion in 'Technical Chat' started by tacopre2002, May 26, 2012.
  1. May 26, 2012 at 4:41 AM
    tacopre2002
    tacopre2002 [OP] Member
    Sean
    Savannah, GA
    2002 tacoma prerunner
    The left knock sensor has gone bad in my 2002 V6 prerunner. The check engine light comes on and off at intervals about every two days. Any idea what the cost would be with parts and labor? Is it a do it yourself job? Would this affect the performance of my truck if I just left it alone..??? Should have the new engine I recently put in it (due to previous owner) had come with new sensors?
    Yet another problem is my half moon seals have dry rotted and are now leaking oil on my exhuast causing an awful smell. I had replaced the engine recently, but should have the new engine come wtih new seals?? are they easy to change out???
    Any information would help me out a great deal!!
    Thanks once again.
  2. May 26, 2012 at 12:11 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    I would look for a used knock sensor. Also see if any other toyota or lexus knock sensors will work. A new one is probably more than $100.
    I went through a knock sensor problem on a 22re, and I found a sensor for $6.
