Bad shaking 50mph+ help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kylestaco132, Nov 13, 2019.
  1. Nov 13, 2019 at 8:27 AM
    Kylestaco132
    Kylestaco132 [OP] Member
    Kyle
    2000 White Tacoma SR5 Prerunner
    Stock as heck atm
    hey guys I’ve run into my first problem with my truck I have a 2000 sr5 prerunner 2wd 3.4 auto, and nothing is aftermarket except the tires I’m running 31x10.5r15 bfg ko2’s which are showing signs of weird tire wear on the front end. The stearing does not feel loose and the rear tires are wearing evenly but the front right (passenger side) seems to be wearing faster than the rest of my tires. I am thinking it could be the wheel balance is off. I couldn’t tell if the wheel bearings were loose and I don’t think they were the issue, do you guys think it’s my balance or is it something else?
  2. Nov 13, 2019 at 8:30 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Rotate the tires F to R. That should give you a clue if its the tires.
    Kylestaco132[OP] likes this.
  3. Nov 13, 2019 at 8:38 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Get your tires re-balanced. Switching front and rear tires might help locate the problem, but keep in mind that's not going to fix it, it will just transfer the poorly balanced wheel to the rear.
    I'm betting it's about time to look into replacing your bushings, ball joints, tie rod ends, etc... A whole front suspension refresh. You might consider doing that, then getting it aligned as well.
    wilcam47, Kylestaco132[OP] and mac84 like this.
  4. Nov 13, 2019 at 8:45 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    When was the last time you had an alignment? In addition to tire pressure, worn suspension parts can also cause uneven tire wear as well as other issues (handling).
    GQ7227 and Kylestaco132[OP] like this.
  5. Nov 13, 2019 at 8:53 AM
    mac84
    mac84 Well-Known Member
    Alabama
    2015 Tacoma TRD Sport 4WD MGM
    Back when I had my 2000 I cured this by replacing front shocks/coils and while I was at it I replaced the tie rod ends. Rotated the tires and once the cups wore out of the tires I put on the back I was happy
  6. Nov 13, 2019 at 9:45 AM
    Kylestaco132
    Kyle
    Stock as heck atm
    I bought this truck Monday I am going to rotate them myself tonight to see if that will narrow down the issue
  7. Nov 13, 2019 at 9:49 AM
    Area51Runner
  8. Nov 13, 2019 at 10:24 AM
    WBilly
    WBilly New Member
    2002 DCSB SAS
    On my last rig, my lower control arm bushing were so worn out it was causing shaking into the wheel. You have to take the pressure off by removing the coilovers to be able to rock them back and forth and truly see how bad they are worn.
  9. Nov 13, 2019 at 10:45 AM
    Kylestaco132
    Kyle
    Stock as heck atm
    Area51Runner[QUOTED] likes this.
  10. Nov 13, 2019 at 10:46 AM
    Kylestaco132
    Kyle
    Stock as heck atm
    Will definitely try that out
  11. Nov 13, 2019 at 7:36 PM
    Colchicine
    Colchicine Well-Known Member
    Newport News, Virginia
    | 2000 | 2.7L | 4x4 | Auto | Standard cab |
    I used to have annoying steering wheel shaking at 55+mph. I tried rotating and rebalancing, and the problem persisted even when I got new tires.
    What fixed it was when I bought an entire set of wheels (from a 2nd gen). So *somehow* one of the rims were bad and it couldn't be fixed with balancing?
  12. Nov 14, 2019 at 9:28 AM
    Kylestaco132
    Kyle
    Stock as heck atm
    I actually fixed my problem by rotating my tires
