Bad shock symptoms
Discussion in '1st Gen. Tacomas (1995-2004)' started by Logans2001, Jan 14, 2019.
  1. Jan 14, 2019 at 6:04 PM
    Logans2001
    Logans2001 [OP] What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Been noticing some noises coming from the front whenever I brake or roll over speed bumps and even when I turn sometimes going slow for about a year now. Almost like a crunching sound. Also found out that increased braking distance, front end dipping while braking, and poor stability control are common symptoms of old shocks. Also of which I have been experiencing. Saw a shop poster today that said shocks should be replaced every 50k miles. True? False? I got my truck and installed bilstein 5100 levelkit/shocks at 200k, I now have 250k.. Is that poster correct?? The mileage numbers and symptoms seem accurate. Just got a steering/suspension diognostic done and they said they found nothing?!
    Has anyone else experienced this?
    Anything helps. Thanks
  2. Jan 14, 2019 at 6:06 PM
    tcjacado
    tcjacado Well-Known Member
    Wheel bearing.
    Ball joints.
    Shocks are typically leaking and bouncy.
    Logans2001[OP] likes this.
  3. Jan 14, 2019 at 6:31 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    If you haven’t had any steering/suspension parts replaced inthat mileage, you should have replaced most of it by now anyway...
    Balljoints, bushings, tie rod ends (inner and outer), shock, and probably even springs. ALL that should be replaced anyway. Ball joints especially.
