Bad Shock?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ElCid11Taco, Aug 21, 2012.
  1. Aug 21, 2012 at 6:20 AM
    ElCid11Taco
    ElCid11Taco [OP] Trashy is Classy
    Parker
    Houston
    2012 TRD Sport
    4x Innovations sliders, Rear Diff Breather Mod...More to come!
    On the way to work this morning and I hear this horrible knocking sound. It is coming from the front driver's side wheel. It makes this noise when I go over bumps in the road. From my experience it sounds like my shock is blown out.....I have a 2012 Sport with 18k miles on it all stock suspension.
    Taking it to the dealer today but just wanted input from TW.
  2. Aug 21, 2012 at 6:28 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Could be a sway bar link/bushings.
  3. Aug 21, 2012 at 8:10 AM
    ElCid11Taco
    Parker
    Houston
    2012 TRD Sport
    I mentioned that to them so we will see. Thanks for the input.
  4. Mar 22, 2013 at 7:15 PM
    oilpatchtaco
    oilpatchtaco New Member
    Graham, TX
    09 SR5 4x4
    I've got the same problem. It's not as bad when I go over speed bumps or pot holes, but when I'm running down dirt roads or uneven surfaces it's awful.
    Took it to the stealership and asked them to check the struts, they said it was fine and that they tightened a skid plate. I'm still stuck with the knock.
    Let me know what they said about yours.
  5. Mar 24, 2013 at 12:43 AM
    galveznano
    galveznano Active Member
    Leo
    Santa ana
    black prerunner
    procomp 2in lift, secondary air filter delete
    If you put a spacer lift its normal, its the sway bar hitting the strut, ull be fine
