Bad Smell?
Discussion in '1st Gen. Tacomas (1995-2004)' started by muliefever, Sep 29, 2014.
  1. Sep 29, 2014 at 1:00 PM
    muliefever
    muliefever [OP] Muliefever
    Tillamook, Oregon
    14' DCSB TRD
    5100's, 887', CB, 265's, FM Deltaflow
    So whenever I put my truck into 4wheel drive and climb the mountains out hunting I get an awful smell in the cab. I am not driving the truck hard or anything, just cruising the Coastal Mountains here in Oregon. truck is a 96 X-cab, 2.7, 5 speed. 205k and counting.
    It doesn't smell like burning engine oil, I know that smell. And I plan on doing this anyway, but I have no idea when if ever the 5 speed or transfer case oils have ever been changed. Been elk hunting so haven't had time :)
    Thoughts?
  2. Sep 29, 2014 at 1:06 PM
    muliefever
    Tillamook, Oregon
    14' DCSB TRD
    Here is an updated picture
  3. Sep 29, 2014 at 1:09 PM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    hmm, check to see if there are any leaks in your diffs. my front diff drips oil and gets on my exhaust pipe and burns. smells horrible. I have to replace the oil seal on the drivers side. Your situation may be similar.
  4. Sep 29, 2014 at 1:09 PM
    wcp0611
    wcp0611 Well-Known Member
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Grey wire and keyless entry. I like stock.
    Before playing the guessing game here, look under your front diff/engine and look under your xfer case and see if they are wet. Gear oil stinks to high hell and stinks worse if it leaks onto the engine and burns off.
  5. Sep 29, 2014 at 1:14 PM
    muliefever
    Tillamook, Oregon
    14' DCSB TRD
    ok great. will do
  6. Sep 29, 2014 at 1:21 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Are you sure it isn't clutch smell? Burning clutch smells awful. If you ride the clutch pedal while off road, that could be what you are smelling. Plus, with your mileage, it wouldn't hurt to replace the clutch. Assuming you haven't yet. Just a thought.
  7. Sep 29, 2014 at 1:40 PM
    Indy
    Indy Master of all I survey.
    Smell like rotten eggs? It's your cat.
    Smell like burning death that sits in your throat and takes days to get rid of? Gear lube.
    Smell like burning cat? It's that cat you ran over and hid on top of your muffler so your wife wouldn't yell at you.
  8. Sep 29, 2014 at 1:46 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    this is what I was thinkin also, I know my '97 2.7 5spd feels like it can barely spin all 4 wheels in 4 hi on flat ground. That's why I usually throw it in 4 low if I'm out creeping around in the hills even if its an easy dirt road. Much easier on the clutch and I generally like the gearing better overall in 4 low, sometimes wish it was even lower at times.
  9. Sep 29, 2014 at 4:11 PM
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    I've got a 2010 that has a bad smell when I have to do some manouvering in reverse. Has done it since new always wondered about it. Doesn't happen all that often so I never really question it till it happens the next time.
  10. Sep 29, 2014 at 4:15 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    If you get a bad smell in the cab, you need to clench harder until you start sweating
  11. Sep 29, 2014 at 5:13 PM
    wcp0611
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    For the win!!
  12. Sep 30, 2014 at 9:17 PM
    muliefever
    Tillamook, Oregon
    14' DCSB TRD
    Ha ha!! That's funny!! It's not the clutch. It smells Hot. I would now assume it's either front gear lube or maybe even power steering from the rack and pinion. Been poring rain and haven't had a chance to dig. Post up tomorrow
  13. Oct 23, 2015 at 5:42 AM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    I think the reason gear oil (Gl-5) stinks so bad is the sulphur compund that is used as part of the EP (extreme pressure) additive.
