bad sound after lift installed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by seakayaker32, May 24, 2012.
  1. May 24, 2012 at 3:31 AM
    seakayaker32
    seakayaker32 [OP] Well-Known Member
    Richard
    Peoria IL
    Tacoma TRD Off Road DCSB
    TRD CAI, Anytime Locker Mod. Modified Doug Thorley Pipe Bomb exhaust (tail pipe cut off just past the rear axle). All Pro winch bumper w/Tuff Stuff Xtreme 12500lbs winch (don't knock it it was free) All Pro IFS skid plate Custom Transfer Case skid plate Old Man Emu lift Desert products chromoly uniball UCAs Rear Differential breather Mod. Front differential drop kit. Satoshi Grill Bushwhacker Fender Flares Wilschur VT series Tiregate Softopper SOS offroad concept sliders w/kick out. Cobra 29 CB
    Okay, so I'm probably asking you guys to shoot in the dark, but I though I'd ask just in case you guys have some insight.
    So I just installed a 3"lift in the front w/add-a-leaf's in the back of my '05 Taco. Now there is this metal against metal sound. It doesn't happen all the time, but when it does, it sounds pretty bad. I've been able to rule out the new tires (they do rub occasionally when I'm backing up and turning, but this sound is very different). Sometimes it sounds like the sound is coming from the passenger side rear; other times I can't tell where its coming from.
    Any suggestions as to what I should try?
    Thx, Rich.
  2. May 24, 2012 at 3:48 AM
    Irish020
    Irish020 Well-Known Member
    Phil
    Pennsylvania
    '05 Tacoma TRD Sport 4 Door Longbed
    ARE Hard Tonneau Cover Flowmaster American Thunder Super 50 Series Stainless Dual Exhaust Toytec Ultimate 3" w/ UCA's
    Did you put new UCA's in?
  3. May 24, 2012 at 3:59 AM
    LAoffroadin
    LAoffroadin BURY ME WITH MY TACO!!
    Joshua
    Northwest
    2012 offroad 4x4
    ICON stage 5 coilers w/ ICON ucas, dakar leaf pack with Fox rears, k&n cai, LED cab light, raceline 16 inch wheels , toyo m/t 33",painted front yota emblem gloss white, retrofit headlights with mirrimoto 3 " lenses running the 6k headlights. Bhlm, bestopper, wet okole seat covers (max 4), weather tech mats,winch with piaa fogs. All pro apex front bumper. Sliders etc
    ihave the same prblem except its coming from the rear like wwhere the bed connects or something
  4. May 24, 2012 at 7:33 AM
    Brunes
    Brunes abides.
    Rotorhead
    Did you put bolts back thru in the right directions??
  5. May 24, 2012 at 7:51 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's
    Check the torque on the u-bolts for the leaf springs. Also, what type of 3 inch lift did you do the in the front? If you have larger springs, you may need a sway bar relocation kit to prevent the sway bar from rubbing against the coil springs.
  6. May 25, 2012 at 3:55 AM
    seakayaker32
    Richard
    Peoria IL
    Hi all,
    I figured it out. Turns out it wasn't coming from then rear. It was nothing more than the dust plates rubbing up against the rotors pushed 'um back our and every thing's fine.
  7. May 25, 2012 at 5:55 AM
    Maticuno
    03 F250 CCSB
    Glad it was something simple! :thumbsup:
