Bad sound coming from rear end. Help! Videos
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jluu44, Apr 26, 2019.
  1. Apr 27, 2019 at 10:53 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    well whats the verdict?
  2. Apr 27, 2019 at 11:10 AM
    yodafr33k
    yodafr33k Well-Known Member
    BC Canada
    18 TRD OR DCSB Cement kings Methods
    like what I said on #17, centre bearing:)
    jluu44[OP] likes this.
  3. Apr 27, 2019 at 11:21 AM
    jluu44
    jluu44 [OP] Well-Known Member
    Jon
    North County San Diego, CA
    2016 Tacoma DCSB 4x4 off-road
    Is the center bearing the same thing as the carrier bearing?
    Skydvrr likes this.
  4. Apr 27, 2019 at 11:35 AM
    yodafr33k
    BC Canada
    yes that caused the noise, vibration from Ujoint (cross joint)
  5. Apr 27, 2019 at 7:26 PM
    jluu44
    Jon
    I think I figured it out. It was a couple loose rebound clips on my leaf springs. They were causing the rattling noise from the lower speed vibrations from the mud tires. Tightened them back up and the sound appears to be gone. Woohoo!
    NMTrailRider and Ch78 like this.
  6. Apr 27, 2019 at 7:28 PM
    jluu44
    Jon
    There was some movement when I checked the carrier bearing but is a little play normal?
  7. Apr 27, 2019 at 8:08 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Take it for what it's worth, as I'm in a low miles truck, but I just slid under mine and have no play whatsoever.
    I'd have to expect some a little further down the road, however.
    I'd imagine the problem manifests itself when a 'little play' turns into some 'slop'.
    jluu44[QUOTED][OP] likes this.
  8. Apr 27, 2019 at 8:12 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Sounds EXACTLY like when my heat shield bolts rusted the shield and the shield was just laying on top of the muffler rattling around.
  9. Apr 27, 2019 at 9:56 PM
    SpeySquatch
    2016 TRD OR DCSB
    Torque bolts to 27 ft/lbs
