Bad stuff is starting in the engine/tranny dunno yet.
Discussion in '1st Gen. Tacomas (1995-2004)' started by alexlies, May 11, 2010.
  1. May 11, 2010 at 4:42 PM
    alexlies
    alexlies [OP] Well-Known Member
    Alex
    Battleground
    2002 4 door 4x4
    need help asap just started today i have a 2002 tacoma double cab v6.
    heres the problem it will shift when driving up to like 50 and it will get to my lowest gear and kinda bogs while just driving. i try to get it to step to a higher gear and it vibrates and then hesitates to shift but does. also when i accelerate it feels like its cutting in and out of power when im on it? and check engin light came on like twice just flashing like 5 times only when i accelerated sometimes. so i got home just now and parked it and noticed its rummbles/vibrates when i push the gas fast but not when i do it slow.
    sry for the messy thread. just wanna get this figured out asap and start troubleshooting. thanks
  2. May 11, 2010 at 4:47 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Sounds like a missing problem. I would change your plugs and wires. And maybe give it some seafoam to clean your injectors and valves.
  3. May 11, 2010 at 4:47 PM
    ETaco23
    Evan
    PNW
    Hey there! just realised your my neighbor! :)
  4. May 11, 2010 at 4:50 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    First of all, it shifts at 50 with your ECT on Normal. If you put it on Power, it will keep it in 3rd to about 55-65 (depending on your accel). This is a bit more acceptable for myself and many others.
    As for rough idling, start with the simple things first:
    -Clean your MAF
    -Seafoam your engine
    -Check/replace your spark plugs
    If that doesnt help, take it to the dealer
  5. May 11, 2010 at 4:51 PM
    alexlies
    Alex
    Battleground
    2002 4 door 4x4
    lol yah it looks like you are my neighbor. nice truck by the way im new to the game.
  6. May 11, 2010 at 4:52 PM
    alexlies
    Alex
    Battleground
    2002 4 door 4x4
    and thank you i will give those things a shot right now
  7. May 11, 2010 at 4:56 PM
    ETaco23
    Evan
    PNW
    thanks! yeah, I would do that, and then come back with an update. good luck man!
  8. May 11, 2010 at 5:00 PM
    ETaco23
    Evan
    PNW
    I would also go get the code/CEL read at AutoZone. so you have a better idea of what it could be.
  9. May 11, 2010 at 5:41 PM
    alexlies
    Alex
    Battleground
    2002 4 door 4x4
    ok im getting mad. its not the map sensor or the plugs do i guess im going down to autozone. will the code still be there if its not flashing?
  10. May 11, 2010 at 5:54 PM
    ETaco23
    Evan
    PNW
    It should still be stored in the ECU.
  11. May 11, 2010 at 5:56 PM
    alexlies
    Alex
    Battleground
    2002 4 door 4x4
    ok thanks ill e heading down there soon hopefully ill get a clue.
  12. May 11, 2010 at 6:00 PM
    ETaco23
    Evan
    PNW
    It could be the wires. If there still factory with alot of miles on them. Or bad/clogged fuel filter, or a vacume line. Try seafoam and cleaning your MAF and Throttle body. There's alot it could be though. But get the code so we can narrow it down.
  13. May 11, 2010 at 6:04 PM
    alexlies
    Alex
    Battleground
    2002 4 door 4x4
    alrighty thank ill keep yah updated
  14. May 11, 2010 at 8:16 PM
    alexlies
    Alex
    Battleground
    2002 4 door 4x4
    ok i got the code checked and it said that all my cylinders are misfiring. so i dunno what to check it cant just be the plugs. its gotta be one sensor or something telling them to do that. anyone have any guesses or answers plz.
    im parking it until i find out whats up.
  15. May 11, 2010 at 8:18 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    The coils are fed by some little control box on the passenger side, on the wheelwell. Guessing if that box went bad it could cause all 3 coils to miss so all the plugs to miss.
  16. May 11, 2010 at 8:25 PM
    alexlies
    Alex
    Battleground
    2002 4 door 4x4
    ok thank you so its kinda a hit or miss if its bad or not no way of testing it?
  17. May 11, 2010 at 8:32 PM
    HerNameIsLucy
    RIP Lucy.
    honestly wouldn't know how, except is has a removable wire connector on it, maybe you could find someone with another 1st gen and "borrow" his box for a test. other than that the toy dealer has better diag equipment but they'd probably charge a small fortune just to diag it.
  18. May 11, 2010 at 8:47 PM
    alexlies
    Alex
    Battleground
    2002 4 door 4x4
    ok ill try my buddys tommaro. crossin my fingers.
    and i get this poping noise coming from the engine bay when im driving. and im thinking that it is the sound commin out of the intake because its misfiring. sound right?
  19. May 11, 2010 at 8:53 PM
    HerNameIsLucy
    RIP Lucy.
    Popping sounds could be backfiring, meaning the timing is way off. That could go up the line all the way from the crank position sensor to the ECU (unlikely ECU). Might end up letting the dealer or a good garage take a peek.
    Then again where is Chris4X4 tonight?
  20. May 11, 2010 at 9:06 PM
    alexlies
    Alex
    Battleground
    2002 4 door 4x4
    i just messaged him with my problem i hope he knows whats up
