Bad TC UCA bushing
Discussion in 'Southern California' started by LBtaco, Jul 21, 2012.
  1. Jul 21, 2012 at 12:48 PM
    LBtaco
    LBtaco [OP] Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    anyone know a local place to buy a new bushing?
    this one on the right is bulging and squeaky :mad:
  2. Jul 21, 2012 at 12:56 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    looks just like mine..when was the last time you greased em?
  3. Jul 21, 2012 at 1:53 PM
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Toytec (Eibach) coils with bilstein 5100 shocks and Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Wheelers Super Bumps,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    Mine looks about the same and that are about the same, unless there is something I don't see in the picture. I would try and grease them.
  4. Jul 21, 2012 at 2:10 PM
    LBtaco
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    I grease them every oil change, 2-3 squirts
    the last few times it really hasn't taken the grease and none builds up between the washers, like the others.
    About a year ago I loosened up the bolt and greased em, saw grease come out.
    But it came back, it's like the grease isnt getting through those small channels in the bushing.
  5. Jul 21, 2012 at 2:28 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    It's not a bad bushing. You need to take them apart and make sure you have the washers on there correctly. On one side of each of the washers there are three small scores placed there to alow the grease to distribute. The budged bushings are the result of the washers facing the wrong way. The scored side of the washer faces the bushing.
    If you are certain they are this way already, you have the bolt too tight.
  6. Jul 21, 2012 at 2:34 PM
    6spdtaco
    6spdtaco Well-Known Member
    Nate
    East Wallingford, VT
    Taco
    Tom Woods driveshaft. TRD short throw shift kit. TRD exhaust. AFE Stage II intake. CBI Bumpers front and rear. Warn 8000i winch/ synthetic line. OME 3" lift w/ dakar springs and 886 coils. ATO Front skid. ARE MX cap. Trail Team FJ wheels. Cooper Discoverer ST 265/75-16 C tires. Diff breather relocation mod.
    The bulging bushing is from OVER greasing. I know first hand. I had it happen to mine. The grease is pushing on the end of the bushing, forcing it out of the UCA. My fix was to take the UCA completely off and remove the bushings. Clean everything, re-install, re-grease, but with less this time. They really don't need a lot of grease, and if they are squeaking it is probably because there is too much grease, distorting the bushing.
  7. Jul 21, 2012 at 2:37 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    When I regrease my uppers I back off the nut for the screw, grease, then retighten
  8. Jul 21, 2012 at 2:38 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    That's where my rambling was headed. Too much grease. And, I found my washers facing the wrong way when I took thing apart to do as Nate described.
  9. Jul 21, 2012 at 2:51 PM
    08pretaco
    Oliver
    az
    squeaking is probably from the uniball itself
  10. Jul 21, 2012 at 4:03 PM
    LBtaco
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    Just jacked it up, loosened, regreased, tightened back to 70lbs instead of 85
    We'll see
    And put tri flow in the uniball
  11. Jul 21, 2012 at 4:27 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    This ^^^
  12. Jul 23, 2012 at 7:04 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Harbor Freight 110v welder garage fab parts.
    IF you greased them, did you back off the shaft bolt? If you did not then the bulge is from the grease trapped and under pressure. You can take a small pointed device and push in the ball on the zerk, while squeezing the bushing to free some of the pressure.
    Typically you loosen the shaft bolt to allow the grease to squeeze around the bushing and on the points in need of grease.
  13. Jul 25, 2012 at 2:36 PM
    LBtaco
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    the bulge is back :confused: my previous attempt did not work.
    ok so this time I took off the UCA re-fitted the bushing and sleeve, applied grease when installing.
    gave it a pump of grease when it was all back together but not tight.
    It oozed out a lttle.
    got it snug, lowered the truck and tightened.. at around 50 ftlbs it started to bulge again. It all seem to be seating properly IDK!!!!
    I guess I'll just replace the bushing like I originally wanted too.
    Anyone know a shop that has them or should I just order online?
  14. Jul 25, 2012 at 4:42 PM
    cbassd
    cbassd Member
    sebastian
    Socal
    02 tacoma
    tc uca, 2.5 icon coilovers with resis, trd supercharger,flow master,u-bolt flip kit,,, all-pro standard pack leaf springs,10 inch travel 2.0 fox shocks with remote resis,21inch led bar,ham and cb radio,4xinnovation sliders, custom from bumper, prp bucket seats and deist 5-point harness
    Go to kartekoffroad in corona they are only like 45 bucks for a set of four
  15. Jul 25, 2012 at 7:07 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    Did you look at the orientation of the washers as stated above?
  16. Jul 25, 2012 at 9:20 PM
    LBtaco
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    Yes, forgot to mention.
    They looked the same , smooth on both sides
    I flipped it fwiw.
  17. Jul 31, 2012 at 1:55 PM
    fidencio74
    fidencio74 Well-Known Member
    Fidencio
    Escondido, CA.
    04 Tacoma DC PreRunner 2WD
    Magnaflow Catback System, King Coilovers, Total Chaos UCAs, Rear 5100, Deaver J59, Greasable shackles, rear steel braided brake hose, Timbren Rear Suspension Enhancement Kit, Kenwood DDX318 HU, JL Audio XD700/5 Amp, Infinity 6830Cs Front, Polk Audio DXi 570 Rear,Pioneer TS-SW2501S4 10" Sub/ Custom enclosure behind the rear seat.
    Did you take the grease out of the busings? The same thing happened to me when i installed mine, I had to dissasembled one of the uca. After that, it was fine.
  18. Jul 31, 2012 at 3:06 PM
    LBtaco
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    went on vacation the last few days.
    Still bad after 800 miles, I plan to take it apart this week.
  19. Jul 31, 2012 at 3:18 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    The best answer for this that I ever heard came from Total Chaos themselves:
    "You want race truck parts? You get race truck sounds."
    FWIW that bushing isn't terribly bulgy and is probably fine for many many more miles. I'd just ignore it.
  20. Aug 23, 2012 at 3:43 PM
    LBtaco
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    well, I had some time and I took off the UCA
    made a drive to Kartek, bought a whole set because they probably need to be changed soon
    now I'm putting them back on.
    You can really see how the bushing is bowed when it's off.
