Bad throttle body?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DanoDavis, Nov 17, 2017.
  1. Nov 17, 2017 at 5:55 AM
    DanoDavis
    DanoDavis [OP] Alright meow
    Daniel
    Allen Tx
    09 Double Cab 4x4 6-Speed V6
    1 1/2" lift with 5100's, custom exhaust, LT Headers, URD CAI, URD MAF Calibrator, Electric fan, Camper shell, retrofit projectors, and other goodies..
    So I’ve been having this weird, intermittent lagging/loss of power issue as of late.
    Sometimes it’ll feel like I’m towing a trailer. Mostly seems to happen the warmer it gets outside.
    Had some 02 codes pop up recently, and replaced both sensors, good to go there.
    I’ve had an issue similar to this on my old 96 3.4 tacoma, and replaced the TPS, and seemed to have fixed it then.
    I cannot recreate this issue, it’s just random, comes and goes.
    Plotting AFR, and 02 input, doesn’t seem like the truck is doing anything odd in those regards during this problem.
    MPGs have dropped a bit overall, as well.
    Just seems like I’m towing a trailer, mixed with a little bit of surging.
    Anyone else have an issue like this?
    09’ 4.0 6-speed.
    Mods in signature.
  2. Nov 17, 2017 at 6:18 AM
    gearcruncher
    Canadain bumper technician
    When was your last tune up ( spark plugs ) and throttle body cleaning ?
  3. Nov 17, 2017 at 6:35 AM
    DanoDavis
    Daniel
    Allen Tx
    10k ago.
    Though I did not pull the throttle body off to clean it, I just opened the butterfly valve and wiped it down.
  4. Nov 17, 2017 at 6:40 AM
    gearcruncher
    assuming you have a scanner ,watch the down stream O2 sensor and the short term fuel trim . Pay close attention to the monitors using mode six on the scanner which can give an indication of a misfire. If the miss-fire is bad enough, your check engine light will illuminate .
  5. Nov 17, 2017 at 6:48 AM
    DanoDavis
    Daniel
    Allen Tx
    Yeah, been monitoring the 02s, and they don’t seem to be doing anything funky at the time of this issue.
    AFR is pretty constant at around 14-15:1
    The scanner I’m using is just the torque app on an old android tablet I’ve got, so I’m able to plot and log.
    I’ll check STFT, and LTFT.
    I wanna say the last time I saw STFT it was around 7.
    gearcruncher likes this.
  6. Nov 26, 2017 at 6:44 PM
    j_cyrus
    j_cyrus Well-Known Member
    Rickman TN
    did you ever solve this problem?
  7. Nov 27, 2017 at 5:36 AM
    DanoDavis
    Daniel
    Allen Tx
    Still have the issue. Haven’t cleaned the throttle body yet. Planning on this week sometime.
    Was gonna do it last week, but we ended up buying a new (to us) car for my wife, and then the holidays. Could not find a time to do it.
    Gonna be cleaning the TB, and then cleaning the screens for the VVTI actuators. At least the TB first, one of these nights when I get home from work. Maybe the actuators this weekend when I have a few hours to spare.
    I’ll keep this thread posted.
  8. Nov 27, 2017 at 5:40 AM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    Start with cleaning your MAF, I had this issue and I ended up having to replace the MAF.
  9. Nov 27, 2017 at 5:48 AM
    DanoDavis
    Daniel
    Allen Tx
    MAF has already been cleaned. Didn’t really seem to make a difference.
  10. Nov 27, 2017 at 5:49 AM
    Red Baron
    Aaron
    07 Radiant Red DCSB
    what code are you throwing? Iirc I had a p1010
  11. Nov 27, 2017 at 5:53 AM
    DanoDavis
    Daniel
    Allen Tx
    No codes at all, that’s the frustrating part. Had 02 sensor codes pop up a few weeks ago, but found that I had a bad downstream sensor on bank 2. Replaced the sensor, and code went away.
    It’s obvious that something is array, as there are times when the truck runs noticeably better, and other times when it feels like a 4-banger.
  12. Dec 4, 2017 at 6:55 PM
    DanoDavis
    Daniel
    Allen Tx
    Well, I finally cleaned the throttle body, and went ahead and pulled the MAF and cleaned it again with MAF cleaner.
    Have driven about 150 miles. MPGs seem to have improved some, but not where they used to be.
    Definitely seemed to make a difference, as it was prettt dirty, but now it seems another issue have cropped up.
    There is a hesitation now when you first step on the gas, almost pseudo surging.
    Like, you hit the gas, head RPMs climb then get kinda dragged back down, like a slipping clutch. No way it’s a bad clutch, as this is a stage 2 URD clutch with maybe 10k miles of very experienced driving.
    This issue is definitely noticeable. On the freeway, I can give the gas pedal hardly any gas at all, and you’ll hear the throttle open up, but the truck will not accelerate. Acts like there is a clogged fuel filter- which I doubt. Installed a new URD fuel pump and filter about 20k ago.
    This gas pedal range where it does it is right where I’m normally giving it gas when freeway cruising, which is super shitty, because it forces me to drive a little faster.
    Fix one thing to break another.. ugh.
  13. Dec 4, 2017 at 6:59 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    In your sig there are a lot of bolt on mods, better check all of them.
  14. Dec 4, 2017 at 8:11 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
  15. Dec 4, 2017 at 8:46 PM
    DanoDavis
    Daniel
    Allen Tx
  16. Dec 5, 2017 at 3:20 PM
    Fullboogie
    Dave
    Houston
    Lol, didn't even notice that. I really think you should check them just to be sure. It took me a long time to figure that problem out. Good luck.
    DanoDavis[OP] likes this.
  17. Dec 5, 2017 at 4:10 PM
    DanoDavis
    Daniel
    Allen Tx
    I’m definitely going to do that, as soon as I’ve got like half a day to set aside.
    How long did it take you to pull the screens, and clean them, and check the solinoids?
  18. Dec 6, 2017 at 9:33 AM
    Fullboogie
    Dave
    Houston
    Couple of hours. Driver's side needs to have the alternator moved aside. Make sure you test the solenoids too. Gotta do both the screens and the solenoids. They work together.
  19. Dec 6, 2017 at 11:20 AM
    Greytacoma1
    Greytacoma1 Senior Member
    dave
    Sacramento ca
    Tacoma dc lb
    Satoshi grill, Plasti derp, Ready lift kit, Wheelers 2 inch aal, Hella 700, Wheather tech floor mats, Blueinstinct armrest cover, sockmonkey bed decal, BHLM, debadge, 35% tint front windows, OEM roof rack, OEM step bar, TRD skid plate, tacomaworld.com decal, stock antenna trimed, gorilla extended lug nuts,diff breather mod, cab mount chop, AVS window visor, spidertrax 1.25 wheel spacers, toytec sway bar relocate, extra d ring mod
    Did this start happening after cleaning the throttle body. It’s an electric throttle body so your not not supposed to clean it on the engine. I forget where I seen or read this but it’s suppose to be off the engine. I cleaned my on the engine and after the cleaning it would feel sluggish and and my rpm would surge slightly up and down. What fixed mine was resetting the ecu by unplugging the battery and letting sit for an hour or two. All good after that.
    https://youtu.be/JPNnHU6PYbo
  20. Oct 2, 2019 at 6:55 PM
    The_Outpost
    The_Outpost Member
    5100s, AAL
    Went through the same issue recently. Cleaned the throttle body & MAF sensor first with no change. Proceeded to unplug TPS and hit it with contact cleaner and been good so far.
