Bad Throwout Bearing Symptoms help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by easyeatlanta, Jun 16, 2012.
  1. Jun 16, 2012 at 7:16 AM
    easyeatlanta
    easyeatlanta [OP] Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    Ok so I think my throwout bearing might be done. when there is no load on the tranny, like when i am not applying power, or i am applying constant power, the shifter and pedal vibrate.
    when i stop if feels like im trying to stop with the car and gear and the clutch not pressed. so it feels like im going to stall.
    Just wondering if my thoughts of the throwout bearing are correct.
    Thanks Tacomaworld in advance
  2. Jun 16, 2012 at 7:24 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    There is no load on the throw-out bearing unless you are pressing on the clutch. If it squeals when you push the clutch in, or feels rough, the bearing could be bad, but that doesn't explain how it feels when you are stopping. That could have something to do with the clutch master or slave cylinder, but it doesn't explain the vibration. How many miles on the clutch? The vibration could be other things in the drive line.
  3. Jun 16, 2012 at 7:34 AM
    BamaToy1997
    Bill
    Navarre, FL
    Obviously without actually inspecting it myself I can't make a proper diagnosis, but my experience with transmissions and clutches lead me to believe that your "when i stop if feels like im trying to stop with the car and gear and the clutch not pressed" is indicative of either a bad clutch, pressure plate, or clutch slave/master cylinder. I would lean more towards a master or slave cylinder problem. How does the pedal feel? How does the truck react when already at a stop, with the pedal depressed, when both in and then out of gear? is there a difference?
  4. Jun 16, 2012 at 7:42 AM
    easyeatlanta
    Eric
    Memphis
    14 DC Trd Off Road
    i have 120,000 miles on my clutch, recently it has needed more gas then usual and feels like you are stalling when coming to a stop. once the clutch is all the way in and i have come to complete stop i can move the shifter around with no difference
  5. Jun 16, 2012 at 7:54 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Sounds like either hydraulics or pressure plate. 120K is about right for a clutch for someone with average driving habits, some people get less, some more. I have rarely seen clutch hydraulics go out, but they aren't expensive to replace.
  6. Jun 16, 2012 at 9:05 AM
    BamaToy1997
    Bill
    Navarre, FL
    Sorry for all the questions, but again, without being there answers to questions sometimes breed other questions to verify.
    How far up do you have to lift the pedal before it starts to grab? Does the pedal engage lower than it used to? (quicker) or do you have to nearly let your pedal off the clutch pedal to get any grip?
    Moving the shifter around is not that big of a deal. What I am curious about is if you have it in gear, and the clutch fully depressed, does the truck try to move if you don't have your foot on the brake if in gear?
  7. Jun 16, 2012 at 11:31 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    With that many miles, there's a good chance your clutch is going. I've rarely seen a clutch on newer rigs go longer than 150k, no matter how nice you drive it.
  8. Jun 17, 2012 at 7:41 AM
    tntacoma
    tntacoma Well-Known Member
    tn
    Just throwing in my 2¢ in, there is a TSB for Throw out bearing for 08' and up. The catch is has to be done before 60,000 miles.
    I found it for a friend and he had it done. The dealer put in a clutch as well as his was worn. They only charged parts for the clutch as they were all ready in there for the throw out bearing.
  9. Jun 22, 2012 at 9:36 PM
    easyeatlanta
    Eric
    Memphis
    14 DC Trd Off Road
    turned out to be bad front u joint
  10. Jun 22, 2012 at 10:58 PM
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    Glad you got it figured out!
    But I have a question my truck started to make a chirp the other day, almost like crickets and when i pusjed the clutch in it went off. So throw out bearing
  11. Jun 23, 2012 at 10:19 AM
    CayucosTacoma
    2004 Double Cab 4x4
    And expensive fix
