bad tie rods?
Discussion in '1st Gen. Tacomas (1995-2004)' started by blakedupriest, Apr 3, 2023.
  1. Apr 3, 2023 at 10:28 AM
    blakedupriest
    blakedupriest [OP] Member
    Hey y'all, slight vibration around 20mph that might bet driveline related but it honestly feels like it's coming from front end. I also get some shaking at higher speeds 65+. the link has two videos one showing the pinon being shook with side to side wheel movement. The other shows the opposite wheel moving with the wheel being shook. My question is how normal does this look? i feel like i notice movement of the pinon in its bushings. are my tie rods or pinion bad? any and all input is appreciated, thanks y'all
    https://drive.google.com/drive/folders/1-96wGlD2kjnlY_PCGUZUqSOTDgyMzjBe?usp=share_link
  2. Apr 4, 2023 at 11:50 AM
    Hotdog7
    Hotdog7 Well-Known Member
    Fred
    1gen Tacoma
    Toytec 2.5-3" lift 2010 rims wheel spacers tundra brake upgrade
    Looks to me you need inner and outer tie rods I would also check. Ball joints all of which can get you in big trouble if they fail
  3. Apr 5, 2023 at 8:56 AM
    blakedupriest
    That was my suspicion, I’m noticing a little play in the pinion bushings do they look like they are worn out
  4. Apr 5, 2023 at 9:23 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    When you say pinion bushings, are you referring to your steering rack (and pinion) bushings? Some movement in the rack is normal (even with fresh ES bushings) I didn't watch your video to see if yours is excessive. Are you doing the work yourself? The rack bushings are cheap, just go for it.
    If they are original, they are toast (this is true for every bushing on the truck).
  5. Apr 5, 2023 at 9:35 AM
    eon_blue
    Azusa, CA
    if you're looking at doing the rack bushings and inner/outer tie rods then I would just get a brand new OEM rack and outer tie rods and throw a new rack on. Comes with the inners and bushings (except for the D shaped bushing). The OEM outer tie rods are cheap to add on.
    cost-wise it might even be cheaper, someone in another thread said a new OEM rack is under $500 at McGeorge right now
    Andy01DblCabTacoma likes this.
  6. Apr 5, 2023 at 10:05 AM
    blakedupriest
    Yeah I’d be doing it myself, it’s not much play but I might as well. It’s 240,000 miles so it’s probably time
  7. Apr 5, 2023 at 12:32 PM
    s92dvr
    s92dvr Well-Known Member
    Dan
    Casa Grande AZ
    2002 Tacoma extra cab 4x4
    Yep, just checked McGeorge, Steering gear PN# 44250-35042 $495.00. "D" bushing - Grommit steering rack housing No 2. PN#45517-35010 $31.72
  8. Apr 5, 2023 at 1:24 PM
    blakedupriest
    Really? I can get new outer and inner for 100 bucks and my rack seems to be working just fine.
  9. Apr 5, 2023 at 1:31 PM
    eon_blue
    Azusa, CA
    I wouldn't run cheap aftermarket tie rods or ball joints on these trucks but that's me
    OEM inners are a couple hundred per side if I remember right, so a whole new rack with them included/installed doesn't cost much more
    s92dvr likes this.
