Bad to put a 2" body lift on a 3" suspension lift?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Patmaui, Feb 18, 2016.
  1. Feb 18, 2016 at 4:03 AM
    Patmaui
    Patmaui [OP] Well-Known Member
    Pat
    Maui
    02 2.7L 4x4
    K&N intake magnaflow exhaust fabtech 6" king coils front procomp rear total chaos uca's 33x12.5x15 bfg km3's 15x10 procomp alloys 4.88 gears
    33"tires are rubbing a bit during tight turns. Adjustable coilovers still set at medium wondering if I'll have to go with a small body lift after I adjust the front to fully clear them(which i want to stay away from). Thanks in advance, its good to finally be a member.
  2. Feb 21, 2016 at 6:21 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Whats it rubbing on?
  3. Feb 21, 2016 at 1:08 PM
    Patmaui
    Pat
    Maui
    02 2.7L 4x4
    rubbing on the bottom inch middle of the inner fender
  4. Feb 21, 2016 at 1:09 PM
    Patmaui
    Pat
    Maui
    02 2.7L 4x4
    in the back of the front wheel wells
  5. Feb 21, 2016 at 1:11 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    Did you hammer the pinch weld already?
  6. Feb 22, 2016 at 8:28 AM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Look up the pinch weld mod. Common place for rubbing issues.
  7. Feb 22, 2016 at 9:57 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Have the alignment shop adjust your caster forward. Problem solved.
  8. Feb 22, 2016 at 12:02 PM
    Patmaui
    Pat
    Maui
    02 2.7L 4x4
    might try the pinch weld after installing the 2" body lift and adjusting the caster forward when i get it aligned. thank you!!!!!!
  9. Feb 22, 2016 at 12:49 PM
    JimBeam
    JB
    2015 Tundra
    I'd hammer the pinch weld before putting a body lift on personally
    I'm running 285/75/16s on SAW coilovers and have no rub up front anymore after trimming the plastic and hammering the pinch weld flat
  10. Feb 22, 2016 at 1:09 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Is that with aftermarket UCA's as well?
  11. Feb 22, 2016 at 1:11 PM
    JimBeam
    JB
    2015 Tundra
    nope
  12. Feb 22, 2016 at 1:15 PM
    boostedka
    James
    NM
    Nice
    Thanks
  13. Feb 22, 2016 at 5:25 PM
    Patmaui
    Pat
    Maui
    02 2.7L 4x4
    i have the total chaos uca's with 33x12halfx15, how does that effect it?
  14. Feb 22, 2016 at 5:32 PM
    boostedka
    James
    NM
    From what I've read they give you more positive caster pushing your wheels forward which allows a little more clearance on the pinch weld. Maybe someone else will chime in to verify or negate this.
    I'm hoping this is the case as I'm going to be fitting 33/1250/15 on my truck here soon as well
  15. Feb 22, 2016 at 7:20 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    That is correct. Some guys have their caster pushed so far forward that their tires rub the washer fluid reservoir and have to relocate it. That is usually guys with 255/85s though.
  16. Feb 22, 2016 at 7:57 PM
    boostedka
    James
    NM
    Makes total sense. After reading up on caster a little more I can totally feel the difference in my steering from installing my TC ucas. My truck likes to stay much straighter and takes a little more effort to turn the wheels. Sounds like that translates as well to more room at the back of the wheel well
