Bad Transfer Case or Rear Differential
Discussion in '1st Gen. Tacomas (1995-2004)' started by metallics2000, Aug 29, 2016.
  1. Aug 29, 2016 at 10:16 PM
    metallics2000
    metallics2000 [OP] New Member
    1999 Toyota Tacoma 3.4l V6 SR5 5SPD 4x4 TRD OffRoad
    Looks like my truck is starting to break down after all these years. I need help on figuring out a noise issue with my truck.
    Symptom:
    • High pitched noise (jet engine sounding) once you get to 35 MPH and up. Noise will be more noticeable at higher speeds. Pressing clutch or putting car in neutral will not help.
    Things already Replaced:
    • Transfer case, transmission, and rear differential fluid with Mobil 1 Synthetic Gear Lube.
    • Center support bearing
    • Both rear wheel bearing and seals
    Could it be the transfer case? Rear differential? Any help/suggestions would be appreciated. Thanks
  2. Aug 29, 2016 at 10:39 PM
    eon_blue
    Azusa, CA
    I'm no expert but I don't see how it could be the t-case if you arent in 4wd. Does it sound like it's coming from the rear? The t-case pretty much right below the driver.
    Does the sound get louder the faster you go or stay the same?
  3. Aug 29, 2016 at 11:03 PM
    metallics2000
    Okay thanks for the suggestion for possibly eliminating the t-case as the cause. It sounds like its coming either in the middle or the rear of the truck; it's difficult to pin point. I plan on putting a camera on various locations and see if I can capture noisier spots on video.
    The noise gets louder with speed.
  4. Aug 29, 2016 at 11:10 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Probably the 3rd member. Put it in jack stands and throw it in second gear
