Bad uniball on new UCA already?
Discussion in 'Suspension' started by JJ04TACO, Apr 14, 2014.
  1. Apr 14, 2014 at 9:39 AM
    JJ04TACO
    JJ04TACO [OP] Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    I installed Camburg UCA's a few months ago. Torqued everything to spec and no issues until now. I can jack up the drivers side and wiggle the wheel left to right and get a few degrees of wiggle. I can feel and hear it in the uniball. I can't visualize what is happening here, and passenger side is tight and quiet. I checked the torque on the bolt and all is nice and tight. They don't squeak at all and have been flawless until now. Maybe Camburg can send me a replacement?
    Also just a side note I have also replaced over the last few months the LBJ's, LCA bushings, TRE's with all OEM parts.
  2. Apr 14, 2014 at 9:45 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    No one is going to send you free parts until you are 100% certain what the issue is. Disconnect the spindle and see if in fact the uniball is the issue. If it is write Camburg a nice letter and see what they say.
    No idea what Camburg uses but my TC uca uniballs from FK were around $40 per ball. My original uniballs only lasted one winter (9 months) because of salt.
  3. Apr 14, 2014 at 9:50 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    UCA uniballs do wear out, but usually with a lot more miles, say 40k. LCA uniballs (often seen in long-travel setups) wear out faster, being more exposed to contamination.
    Got a picture of the driver's side uniball showing the conditions of the misalignment spacers? If the installer isn't careful, the misalignment spacer lip can get pinched by the bearing housing on installation (happens with both DIY and professional mechanics).
    Did you replace both the outer- and inner tie rod ends?
    If you've isolated the problem to the uniball with good confidence, contact Camburg for a replacement.
  4. Apr 14, 2014 at 10:15 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    I replaced the outers only, and thats a good call there. However now I'm not so sure. I stuck my head in the wheel well and listened while moving the wheel and the sound seems to come from "everywhere". I got underneath and did the same and it sounds like its coming form the wheel area, i.e. spindle side. Could a failing CV do something similar? Close to the hub?
    (EDIT)
    After thinking about the CV, That doesn't make sense. The CV wouldn't allow the wheel to move in the manner in which it does...so back to ITR?
    When I was replacing the OTE I did give the inners a tug and a twist and they seemed fine. I'll have to get a buddy to help me out here and track this down. I'm not so sure its the uniball. How about a wheel bearing? I only get play from side to side and not from the 12/6 o'clock positions. It has to be an ITR...
  5. Apr 14, 2014 at 2:53 PM
    KenLyns
    Belly of the Beast
  6. Apr 14, 2014 at 5:00 PM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Yeah left and right wiggle sounds like tie rod or rack. An up and down wiggle would be ball joints.
  7. Apr 15, 2014 at 7:36 PM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    If it were a rack issue would both sides have the same issue?
  8. Apr 15, 2014 at 7:39 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    not if its in the tie rod.
  9. Apr 16, 2014 at 7:04 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Awesome, thank you!
  10. Apr 16, 2014 at 9:47 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    I went thru the exact same thing, you could wiggle the UCA arm and wheel would not move, it was the Uni-ball cup was bigger the OD of the Uniball shoulder. I have seen and heard this more then a few times and always about Camburg.
  11. Apr 17, 2014 at 7:39 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    The wheel is moving from side to side enough that the uniball is moving too like a turning wheel. All is tight though as it should be with the uniball i believe.
    I just ordered inner tie rods, and it had better be the culprit or my wife will have my nuts hanging on the mailbox and a bon fire in the front yard dancing with face paint on. I've spent too much on the truck in the last several months.
    Lift, Tires, UCA's lower ball joints, outer tie rods, inner tie rods, bushing replacement for LCA's and the steering rack.
  12. Apr 20, 2014 at 12:35 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Inners are done. They seemed ok, but so did my upper ball joints before I cleaned out the grease. They were clearly shot. There seems to be less play, I'll drive it around a bit and check again...
