Bad vibes, Stumped on Stopping Vibrations on my 2000 Taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tylerb, Jan 9, 2024.
  1. Jan 11, 2024 at 6:35 PM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    When I bought my '95 a few years ago, she had a bad vibration that would start around 40-50mph and get progressively worse. Nothing subtle about it, at all.
    Assumed it was the old, dried out tires, since she came out of Nevada. Ended up being the front wheel bearings.
    5sp, 3.4, Xtracab
  2. Jan 11, 2024 at 10:56 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Tylerb
    Dang thought I was on to something
    U mentioned prior owner might of chinched out on new clutch in the past
    IMO, there would be 5% chance that he paid the $40 to resurface the flywheel
    possible so glazed/groves unbalanced?
    Like u stated, could be the issue
    I know some manufacturers have a ‘inspection window’ on bell housing
    Unk if our Tacos have thou
    plz let everyone know what u find
  3. Jan 12, 2024 at 5:40 AM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    I have been fighting a vibration recently in my truck. I'm thinking its related to exhaust since I replaced the manifold with an LCE header but getting under the truck it barely vibrates.
    When in D or R only after the truck is up to normal operating temp and idle is down to normal (650ish) the truck shakes like absolute madness. When decelerating around 20mph I have a shudder which I'm fairly sure is related to the torque converter if I shit into neutral the shudder is gone. Same thing during idle if I shit to neutral it goes away and is smooth.
    Can a failing torque converter produce these issues at idle? Besides that one shudder around 20mph the truck is smooth and responsive. I've replaced just about everything except engine/trans mounts and the trans mount is going to be swapped in a week or 2 since I found some rubber separating on it.
    No codes, no misfires, cleaned TB when fuel injectors were replaced, IAC responds well according to my scanner, fuel trims are as good as its gonna get on an old truck (LT around -3), no vacuum leaks as far as I can tell, plugs/wires changed ~15k ago
  4. Jan 12, 2024 at 7:26 AM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    I’ll add in that I also had old rear drums that caused my vibrations. New drums and shoes made a big difference.
