Bad Vibration at 30mph!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Inayotacoma, Feb 11, 2025.
  1. Feb 11, 2025 at 8:31 AM
    Inayotacoma
    Inayotacoma [OP] Member
    1997 Tacoma Xtracab 4x4
    I’ve got a real bad vibration between 25-35mph. It goes away completely once I hit 40, and feels smooth as ever. I just replaced carrier bearing and u joints on the shaft, so it can’t be that. Have recently done CV Axles, LBJ, UBJ, rotors and pads, steering rack and tie rods, as well as changed oil on both difs, transfer case, and transmission. (5spd). Could it be tires? Just feel it’s super strange that it has such a tiny threshold where it feels like the front end might come undone and then it disappears at 40. Any thoughts would be appreciated !
  2. Feb 11, 2025 at 8:33 AM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    Cupped tires?
  3. Feb 11, 2025 at 9:09 AM
    Inayotacoma
    If anything it’s got edge wear- used to be a hunting/farm truck so that makes sense.
    I’m going to get them balanced now and see if that makes any difference!
    MadDaddy likes this.
  4. Feb 11, 2025 at 9:16 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    I didn't see alignment in your post, have that done while you're at it.
  5. Feb 11, 2025 at 9:47 AM
    Inayotacoma
    Sorry forgot to mention but yes alignment as well after replacing the rack last month.
    Black97v6MT likes this.
  6. Feb 11, 2025 at 9:50 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Did you align the drive shaft back like it was before you took it apart for the Ujoints? That will cause a vibration if you didn't.
    Inayotacoma[OP] likes this.
  7. Feb 11, 2025 at 10:18 AM
    Inayotacoma
    I did, had the bad vibration and saw the carrier bearing was completely shot so thought that must be what’s causing it, so I decided to order u joints and get them all done at the same time. U joints were actually not in bad shape at all, but I did them anyway with carrier bearing, marking all the points of separation.
    But, it didn’t solve the vibration.
  8. Feb 11, 2025 at 11:43 AM
    Glamisman
    Glamisman Well-Known Member
  9. May 7, 2025 at 4:31 PM
    Inayotacoma
    For anyone in the future who might need this- the vibration was solved. I needed to drop the center bearing down a couple inches to get a better angle on the double cardan joint and the angle going into the rear dif
