Bad vibration (dash) when apply brakes !!!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by 67tone67, Jun 9, 2011.
  1. Jun 9, 2011 at 2:46 PM
    67tone67
    67tone67 [OP] Well-Known Member
    Tony
    Fulton Ms
    04 Dbl cab TRD
    Ok here it goes....just when u think uve figured it out... Ok . I thought it was bad brakes so i did a total brake job....turned rotors and drums new pads and shoes... Not much change. I have just replaced all the ball joints and drivers wheel bearing with little to no change.... Im at a standstill and am getting aggravated! Anyone had ( has) this problem please help. 98 tacoma 4x4. :( and.... Truck also has new tie rods!
  2. Jun 9, 2011 at 8:39 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Any vibs in the steering wheel when you apply the brakes? What about the floorboard/drivers seat?
  3. Jun 10, 2011 at 2:48 AM
    67tone67
    Tony
    Fulton Ms
    04 Dbl cab TRD
    Yes the wheel does shake.... Feels like the front end is falling out from under truck.... Agravatting rattle/ shake.
  4. Jun 10, 2011 at 7:41 AM
    bicklebok
    bicklebok Well-Known Member
    Ronnie
    Montgomery, AL
    2000 Xtra Cab 4x4 SR5
    I know you replaced the rotors, but my first impression is the rotors. They usually cause that shake during hard braking from a pretty good pace.
    Have someone wiggle the steering wheel slightly back and forth, back and forth while your under the truck and look at all the steering linkages for anything wore out or loose.
  5. Jun 10, 2011 at 8:22 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I too think it could be your rotors. Sometimes just turning them isn't enough. I would suggest you consider new, OEM rotors and pads as the next step.
    A vib in the steering wheel when brakes are applied indicates the source is the front brakes.
  6. Jun 11, 2011 at 6:27 AM
    67tone67
    Tony
    Fulton Ms
    04 Dbl cab TRD
    I ve already replaced the pass side rotor bc i thought that might be the culprit.... Im going to get another for the drivers side and ill post the outcome... Thanks guys.
  7. Jun 11, 2011 at 9:58 AM
    67tone67
    Tony
    Fulton Ms
    04 Dbl cab TRD
    New rotor for drivers side... Poof!! Problem solved... Thanks guys.
  8. Jun 11, 2011 at 1:48 PM
    bicklebok
    Ronnie
    Montgomery, AL
    Congrats man!
  9. Jun 11, 2011 at 5:56 PM
    67tone67
    Tony
    Fulton Ms
    04 Dbl cab TRD
    Thanks again..
  10. Jun 26, 2011 at 12:05 PM
    Adam Baum
    Adam Baum Well-Known Member
    PCS
    01 PreRunner SR5 debadged
    i just turned my rotors today, and the vibration is still there when i apply the brakes. Did you use replacement OEM rotors and pads? My 01 DC prerunner is stock other than the 265/75/16's.
  11. Jun 26, 2011 at 12:35 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    oem or brembo blanks are good rotors to use.
    OP, congrats on the fix. vibration while braking is almost always time for new rotors. sometimes, rotors warp and turning them won't solve the issue. good job.
