Bad Vibrations in Wheels and Pedal from 2k-2500 rpms!
Discussion in 'Technical Chat' started by Mr_Stagger_Lee, Aug 6, 2018.
  1. Aug 6, 2018 at 8:51 AM
    Mr_Stagger_Lee
    Mr_Stagger_Lee [OP] Active Member
    Hi Folks!,
    I have a 2017 TRD OR and am experiencing a buzzing vibration in the wheel and pedal when accelorating through 2k-2500 rpms. Also is constant when I hover in that range -- 5th gear 70mph for instance.
    I took it to the dealership and they said thats normal which I think is bullshit!. My buddy has a 2018 and his does not do that at all.
    The truck is stock and has no extra lift.
    It's driving me crazy, please help!
  2. Aug 6, 2018 at 8:59 AM
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    rebalance the wheel/tire perhaps
  3. Aug 6, 2018 at 9:01 AM
    Mr_Stagger_Lee
    Wheels and tires are balanced. It feels more like a driveline issue. Its a buzzing vibration not a shake if that makes sense :/
  4. Aug 6, 2018 at 9:06 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Coming from inside the cab?
  5. Aug 6, 2018 at 9:11 AM
    Mr_Stagger_Lee
    Yes sir specifically the steering wheel and gas pedal. You can also hear it. I read about others having that issue with the 2016s but with no solution.
    Also the transmission keeps hunting for gears -- that could be unrelated through
  6. Aug 6, 2018 at 9:13 AM
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    Some have solved it by replacing the needle bearing. Check out ECGS needle bearing.
  7. Aug 6, 2018 at 9:14 AM
    roguegs
    Angelo
    V8 T4R
  8. Aug 6, 2018 at 9:20 AM
    Mr_Stagger_Lee
  9. Aug 6, 2018 at 9:24 AM
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    @Mr_Stagger_Lee like what @roguegs said
  10. Aug 9, 2018 at 11:32 AM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Please post your findings after your your troubleshooting.
    Inquiring minds want to know.
    TOMB
  11. Aug 9, 2018 at 11:36 AM
    Mr_Stagger_Lee
    Will do!
  12. Sep 13, 2019 at 6:51 AM
    Mitch65
    Mitch65 Well-Known Member
    Did replacing the needle bearing solve you issue? Mine does the exact same thing and im just curious.
  13. Oct 2, 2019 at 9:28 PM
    Trona
    Trona Member
    2012 OR TRD Double Cab 4x4
  14. Oct 3, 2019 at 4:58 PM
    Mitch65
    The vibration is so minor I would definatly not let it stop me from owning a 3rd gen. Its there and I feel it but its not a big deal to me
