!BAD VIBRATIONS WITH 5100 @ 1.75!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zbouncer, Aug 7, 2011.
  1. Aug 7, 2011 at 3:01 PM
    zbouncer
    zbouncer [OP] Well-Known Member
    SA,TX
    05 PreRunner
    2" Revtek lift 285-75-16 BFG MT
    Hello guys I just installed my 5100s and set them to 1.75 for a level look, 05 prerunner 2.7 2wd and i do not have the tsb done. Yes i used the search function and my previews did not show my exact concern. The ride feels great until i get to 32mph and that is when i get vibrations from hell. it shakes the whole cab and rattles the dash but only under acceleration. Could this be my drive shaft angle? Any help would greatly appreciated :)
  2. Aug 7, 2011 at 3:02 PM
    SilverTacoZack
    SilverTacoZack Well-Known Member
    Zack
    Elgin, SC
    2011 FJ trail teams
    May seem obvious, but have you checked all your lug nuts after putting your wheels back on after the install? Just a thing to check first. I've had mine go loose in the first 15 miles whenever I do my tire rotations, and so I always check them after 50 miles or so.
  3. Aug 7, 2011 at 3:07 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    So as of now you have no lift in the back right? It can't be your drive shaft.
    Check you installation for loose bolts and proper torque
    Fyi: You will need an alignment.
  4. Aug 7, 2011 at 3:07 PM
    zbouncer
    SA,TX
    05 PreRunner
    Yup, thought that might be the problem as well. It vibrates pretty bad and i dont want to mess anything up especially since this is my only mode of transportation.
  5. Aug 7, 2011 at 3:08 PM
    zbouncer
    SA,TX
    05 PreRunner
    correct no back lift, and yes i will need an alignment but that wouldnt cause crazy vibes in cab :confused:
  6. Aug 7, 2011 at 3:16 PM
    zbouncer
    SA,TX
    05 PreRunner
  7. Aug 7, 2011 at 4:30 PM
    zbouncer
    SA,TX
    05 PreRunner
    Okay I just finished triple checking torque on all of the bolts and everything is solid. I did notice the 2 piece drive-shaft has a lot of play where the two pieces connect...is that normal?
  8. Aug 7, 2011 at 4:46 PM
    zbouncer
    SA,TX
    05 PreRunner
    someone...anyone...
  9. Aug 7, 2011 at 5:14 PM
    Reepur
    Reepur Well-Known Member
    Brevard, NC
    '10 RC Black 4x4 2.7L
    265/75/16 BFG KM2 's on XD Hoss's 2.5" lift/4xBillies, OME 885's, Firestone Ride-Rites Desert Specialties UCA Volant CAI Grillcraft Grill Kobalt Slim Line Box Weathertech mats and Ventvisors. DTRL mod. 4 Lo -Trac Mod. Int. Wiper Mod. rcbs204 4x4 LEDS URD Short Shifter Plate Front bumper with Smittybilt XRC8000 winch Body Armor rear bumper with swing out tire carrier. ATO Front Skid Ultragauge BHLM
    I had the same issue and it is most likely your drivers side front axle. Too severe an angle. You can check that by driving in 4wd at 30- 40 mph. If it goes away , it's the axle.
    I corrected mine with a homemade 3/4" diff drop. Tho once in a while I still get a light hum. I am not going to worry bout it tho.
  10. Aug 7, 2011 at 6:04 PM
    RideFast
    Jesse
    Tacoma
    Correct me if I am wrong but prerunners do not have cv axle's. and do not require diff drop kits.
  11. Aug 7, 2011 at 6:56 PM
    RideFast
    Jesse
    Tacoma
    Bump, you need a prerunner lift expert!!!
  12. Aug 7, 2011 at 7:03 PM
    SilverTacoZack
    Zack
    Elgin, SC
    2011 FJ trail teams
    It is possible it is a problem with the carrier bearing (the piece that connects the two pieces of the driveshaft). Recently I read of another member having this problem when he had too much rear lift. I'd be suprised though if just a front 1.75 lift caused that though.
  13. Aug 7, 2011 at 8:03 PM
    RideFast
    Jesse
    Tacoma
    I was thinkin the same thing but first I would try getting the rear lift on there asap to see if the vibes go away.
  14. Aug 7, 2011 at 8:39 PM
    zbouncer
    SA,TX
    05 PreRunner
    Well its a 2wd so its not the front shafts, and I replaced the revtek 3" lift kit with the 5100s for a better daily driver and removed all lift components including blocks and spacers. it actually sits lower now so i dont think angle has anything to do with it?
  15. Aug 8, 2011 at 4:59 AM
    Tidrow
    Tidrow Well-Known Member
    Austin
    PreRunnin' 08
    BHLM, All Black grill, Fog light Mod, AFE pro dry, 20% tint, Weathertechs, Kenwood deck, Bridgestone AT Revo 2
    I used to have bad vibes, the tires were not balanced correctly. :cool:
  16. Aug 8, 2011 at 5:28 AM
    zbouncer
    SA,TX
    05 PreRunner
    Just put on new tires that were balanced at discount tire and were perfectly balanced 300miles ago, could they have been thrown off balance from removing the tires in order to install the 5100s?
  17. Aug 8, 2011 at 6:38 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
  18. Aug 8, 2011 at 7:51 AM
    zbouncer
    SA,TX
    05 PreRunner
    Hmmm...my upper and lower ball-joints were a little jacked, but were not causing bad vibes before, could the new angle cause this sort of stress and cause cabin shaking vibes:confused:
  19. Aug 8, 2011 at 8:12 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Did you used to have rear lift blocks and you removed them? If so, check the torque on your u-bolts and that would mean you did change the rear geometry which could be causing your vibrations. How much play do you have at the carrier bearing? There is some movement, but shouldn't be a whole lot.
    Balance could have been thrown off if you knicked a wheel weight. You'd have to be pretty rough with the wheels though to break off the wheel weight but it's possible, especially if the shop used stick on weights.
  20. Aug 8, 2011 at 8:27 AM
    zbouncer
    SA,TX
    05 PreRunner
    I did remove the rear blocks and torqued the hell out of the ubolts using a breaker bar and my little brother who is 6' 3" and 240lbs of man-child! The play of the drive-shaft was not back and forth it was more of an up and down where the 2 pieces meet, I know there is supposed to be some play but there was about a 1/4" gap between the round bushing and the round mount where they connect, is that normal :confused:
    I did use the tires as a seating device so I wouldnt jack-up my lower back and could have possibly knocked off one of the adhesive weights, but I dont remember seeing any weights as I cleaned up the parking lot.
