Bad water pump
Discussion in 'Technical Chat' started by Patrobs, Jan 10, 2011.
  1. Jan 10, 2011 at 7:29 AM
    Patrobs
    Patrobs [OP] Well-Known Member
    Patrick
    New Hampshire
    2012 Dbl Cab Short bed TRD Offroad
    So I just dropped the truck off at the stealership. The past couple of days I have had this strange burning smell coming from the truck after I have run it for more than 10 minutes. They called me back saying the water pump is bad and is leaking which is causing that smell. My question, The truck only has 34,000 on it. Is it common for these trucks to have water pump problems? If the water pump is going so early is there anything else I should be looking for before the warranty runs out?
  2. Jan 11, 2011 at 5:32 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    That's scary:eek: ! My 2.7 has 35,000. No problem so far. My 2000 2.7 done at 91,000.
  3. Jan 11, 2011 at 7:18 PM
    GiverDeaner
    GiverDeaner Member
    Kevin
    Kamloops,BC
    Nicest 2ndGen in town Wannabe
    3"lift,33/11.5's,TRD Bronze rims,HID fogs and headlights,All LED's,Black front lip,Fogs on when high beams on mod.
    If your truck is under warranty what did they steal from you?
  4. Jan 15, 2011 at 12:03 PM
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
    BAMF kick out sliders, SkidRow skids,Pro Comp 7069, Kelly Safari TSR 285's, Elite front bumpa, OME 883 & Dakars w/ D6XL AAL, Nitro sport shocks, Eddie209 Soft topper, Satoshi, k&n fipk, Clarion vx400, Ultra Gauge, Debadgination mod
    Sitting here at my local Toyota dealership. 73,000 miles on my 08 Tacoma and there are replacing the water pump. I have the extended warranty so I only need to pay my $50 deductible.
    My 06 Tacoma also had the water pump replaced at about 45k miles... WTF Toyota.?.?.
  5. Jan 15, 2011 at 1:46 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    My '01 had the timing belt replaced at the 90,000 mile service per schedule.. They noticed a drip from the water pump, so with it exposed it was much cheaper to replace it right then. Nothing ever 'failed' on my '01... had it for almost 5 years and 136,000 miles!
  6. Jan 15, 2011 at 2:10 PM
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
    Yeah my '99 Tacoma never had any issues. I put over 475k miles on it. Still had stock auto trans and stock 3.4v6.
  7. Jan 15, 2011 at 2:17 PM
    george3
    New Jersey
    It's always smart to do the water pump when you do the timing belt. You're paying for most of the labor anyway.
