Bad weld job? (Sliders)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tekneek, Aug 25, 2023.
  1. Aug 30, 2023 at 2:17 PM
    #61
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    They welded the gussets on the wrong side. They're supposed to be on top to resist the force of hitting a rock
    Kwikvette likes this.
  2. Aug 30, 2023 at 2:20 PM
    #62
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    isn't that what I said? That doesn't mean "the slider is upside down".
    Bivouac likes this.
  3. Aug 30, 2023 at 2:20 PM
    #63
    treyus30
    Trey
    Mesa / AJ, AZ
    oh, I guess. Think the replyee might have been taking a liberty on their phrasing
  4. Aug 30, 2023 at 2:24 PM
    #64
    treyus30
    Trey
    Mesa / AJ, AZ
    here you go, freshly scanned
  5. Aug 30, 2023 at 2:39 PM
    #65
    Gen3TacomaOBX
    S
    Thank you for including the instructions.
    Interestingly within the instructions.. step 17 says the [triangle] gusset can go on either the top or the bottom. So according to the 4x instructions OP's welder didn't mount the gusset upside down.
    I'd think gusset on top would be optimal for all instances UNLESS the tube stand-off is mounted so high on the frame plate that there isn't enough room for such orientation. <shrug>
  6. Aug 30, 2023 at 2:47 PM
    #66
    treyus30
    Trey
    Mesa / AJ, AZ
    I'm not even fully welding mine on tbh. It's too difficult to get in there on top and zero room on the bottom with the square tube
  7. Aug 30, 2023 at 4:37 PM
    #67
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Yes, different variations. Have even customized 2 sets to fit KDSS on GX470 and a 4Runner. They’re in my opinion one of the best sets out there. I got my wife the basic set for her T4R for $230 shipped and they arrived in 4 days.
  8. Aug 30, 2023 at 6:14 PM
    #68
    Gen3TacomaOBX
    S
    Definitely hard pressed to beat their prices considering the stock material is half the cost of $300 (in my experience.) Add bending, cutting frame plates, coping tube and there's little margin. I've recently bought 1.75" HREW and 3/16" plate at [reasonable] volume. I do think they could/should offer an upgrade option for beefier bolt on frame plates.. but that requires a certain amount of custom work per model that may solidly boost the price.
    Bivouac and Kwikvette like this.
  9. Aug 31, 2023 at 3:56 AM
    #69
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Thanks for posting this Sir!!
  10. May 1, 2024 at 9:34 PM
    #70
    Tuluk
    Tuluk Well-Known Member
    1999 trd manual 4x4 ext cab
    Little update here, I went ahead and tried this weld myself. Overall, it is definitely doable, thanks to those who said to try.
    I’m not sure what got OP’s guy so out of whack. I did this with stick and ran 6013 and it was pretty straight forward, even with this being my first true out of position vertical weld .
    I Used a wire wheel on the frame and plates and laid down 2 passes per side. I had a hard time terminating the passes, as you can see, but they were easy to grind out and wrap around the bottom edge after getting a new position. The gauge of steel used for the rails and the plates is so thick you don’t have to worry about blowing anything out.
    The set up and tacking of the legs and gussets took way longer than the actual finish weld.
  11. May 2, 2024 at 10:28 PM
    #71
    foresterfields40
    foresterfields40 Well-Known Member
    ‘99 Tacoma 3.4 4x4
    I’d be willing to bet the OP’s welder decided to weld the plates to the sliders before install and then due to clearance issues had to drop the plates lower on the frame for clearance between the sliders and rockers
    Tuluk likes this.
  12. May 2, 2024 at 10:49 PM
    #72
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Regardless of the order of operations, the welds pictured in OP's first post are just.. drastically poor.
    On both of those photos, at least 50%, perhaps more, of the total weld length looks "cold," with substandard-to-zero penetration at all.
    I suspect that has more to do w/ the welder not having an adequately-powerful welding machine. Or if it does have enough power, he didn't know the correct amperage / voltage to use for the thicknesses of the frame & slider plates.
    I would tell him to grind it all off at his expense, give you back whatever parts of the sliders can be salvaged, and then take it to a pro 4x4 fab shop with a proven track record to clean up & attach properly.
    michael roberts and grizzlypath like this.
