Bad Wheel Bearing (Video)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ticaz, Jan 19, 2017.
  1. Jan 19, 2017 at 5:46 PM
    ticaz
    ticaz [OP] Well-Known Member
    Dan
    2010 Timberland Mica DCLB 4x4
    Hello!
    Just wanted a second opinion from people that have experienced this before. Questioning a bad wheel bearing. Have the classic howl/growl at highway speed (mostly 100kph or over before it really gets noticeable) with slight vibration. Changes upon cornering. Anything under 100kph, its not really noticeable however.
    Jacked up the front today and checked for play/noise. Very little play noted, but there is a little present, with a slight clunk. Both sides are about the same. There is some rotational noise... but it doesn't seem super harsh or crunchy (again, both side about the same). Do the front rotors/callipers make this much noise, or am I looking at doing my bearings soon?
    For info sake, this is on a 2010 tacoma 4x4 with 150,000km. I purchased this truck used, and from the service records I had the dealership pull, bearings have never been done.
    A quick video of what I am dealing with.
    Thanks for looking, and thanks for any input!
    Cheers.
    nj636 and ChadsPride like this.
  2. Jan 19, 2017 at 5:56 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Is there play when you rock it with your hands at 12 and 6? Do you feel the vibration driving straight forward? Does it get worse when you turn one way or the other and then get better when you turn the opposite way? Have you rotated the tires to see if it's an off balance tire?
    ChadsPride likes this.
  3. Jan 19, 2017 at 6:09 PM
    ticaz
    Dan
    Play seems to be only at 9 and 3, can't get anything at 12 and 6. From what I can tell, tie rods are good however. Doesn't seem to be where its coming from. I just rotated the tires today while I had it in my garage and changed the oil, will see if that makes a difference.
    Yes, noise disappears when turning/cornering on the highway in one direction. Turning/cornering the other say seems to make no difference.
  4. Jan 19, 2017 at 6:10 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    I would say it's a bad wheel bearing for sure
    nj636 and ticaz[OP] like this.
  5. Jan 19, 2017 at 6:20 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    My passenger side front went bad, drove on it for about 4 months. Had the symptom of turning right, went away, turning left, got louder. Never had any play when jacked up and turning wheel, but once the hub's were removed there was a definite grind when rotating the passenger side versus the driver's side. If you have play when rocking it at 12 and 6, then it is REALLY worn. I would replace both fronts as soon as practicable.
    ChadsPride and ticaz[OP] like this.
  6. Jan 19, 2017 at 6:23 PM
    ticaz
    Dan
    Thats what I was afraid of. Thanks for the input. Guess I'll be ordering a set from nj636.
  7. Jan 19, 2017 at 6:27 PM
    08TacoTrD
    08 TRD Offroad
    Mirrors what I had recently and I replaced both front hub/bearings and the noise/vib went away.
  8. Jan 19, 2017 at 6:28 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    ChadsPride[QUOTED] likes this.
  9. Jan 19, 2017 at 6:29 PM
    ecoterragaia
    Central Virginia
    I bought mine from NJ626 too, he does great quality work and I received them very well packaged. Been running them for almost a year now and all good. I think BamaToy1997 also offers a similar bearing/hub assembly for similar pricing.
    nj636 likes this.
  10. Jan 19, 2017 at 6:32 PM
    robssol
    Rob
    S. Wisconsin
    BamaToy1997 :thumbsup:
    SJC3081 and ecoterragaia[QUOTED] like this.
  11. Jan 20, 2017 at 4:50 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Wheel bearings on a Tacoma are just regular maintenance like changing your oil or replacing your frame.
    UncommonLife, nj636 and robssol like this.
  12. Jan 20, 2017 at 8:23 AM
    robssol
    Rob
    S. Wisconsin
    Yeah, kinda like that:rolleyes:
  13. Jan 21, 2017 at 7:53 AM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    Dan, do you mind if I share your post/video in my thread?
  14. Jan 21, 2017 at 7:53 AM
    nj636
    Kev
    Jersey
    well said :p
  15. Jan 21, 2017 at 8:06 AM
    george3
    New Jersey
    Thanks. BTW I bought 2 from U. Install easy peese.
    nj636[QUOTED] likes this.
  16. Jan 21, 2017 at 8:15 AM
    nj636
    Kev
    Jersey
    Yes sir how could I forget :)
  17. Jan 21, 2017 at 3:07 PM
    ticaz
    Dan
    Of course, please go ahead! Thanks for asking.
  18. Apr 24, 2017 at 1:09 PM
    CCKC68
    CCKC68 New Member
    Carl
    2010 White Tacoma 4X4
    na
    Yep, you all make me feel a lot better....my 2010 Takoma with 125K miles has a front left wheel bearing that went bad. I had a guy rotate my tires for me and he picked it up, it was not nosy yet when driving, but sure could hear it when up on the rack. Funny the right side sound and feels fine, just the left side! Just normal maintenance on these buggies.....I will now keep a close eye/ear on the front left side....
