BadDNA's M416 build
Discussion in 'Other Builds' started by BadDNA, Aug 28, 2019.
  1. Oct 8, 2019 at 12:27 PM
    BadDNA
    BadDNA [OP] Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    BYOC (chainsaw), the property is almost entirely forested and will need some clearing.
    Grand dude likes this.
  2. Oct 8, 2019 at 12:29 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Okay I'll buy 2
  3. Oct 8, 2019 at 12:41 PM
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Deal.
  4. Sep 1, 2020 at 12:10 PM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Waiting... Impatiently!
    :playball:
  5. Sep 1, 2020 at 12:15 PM
    BadDNA
    Eammon
    Cabot, VT
    Garage build out had to happen first. That's almost done to a workable state, so the trailer build might resume over the winter, or next spring.
  6. Mar 12, 2021 at 7:42 AM
    BadDNA
    Eammon
    Cabot, VT
    Progress - of a sort. I'm definitely not building, or doing any non-critical work in the garage over winter until I get some heat installed out there, but now that it's warming up, and I've got most of the equipment I'll need to get this thing underway, we're buying parts and formulating a plan of attack.
    @Skierrichy - I remember some of the challenges you had offroading your trailer and not having brakes on it, so I ordered brake hubs and not just idler hubs. I can always remove the brakes if there's an issue, but I'd rather have them and decide to disable them then build without and decide I want them later.
    Ordered:
    Timbren 2000 lb HD Axle-Less Trailer Suspension w/ 4” Lift & Long Spindles
    Timbren 3500 lb. Electric Brake Hubs - 6x5.5 Bolt Pattern
    etrailer Trailer Wiring 7-Way Upgrade Kit w/ Junction Box and RV Style Connector
    Hopkins Engager Push-To-Test Trailer Breakaway Kit with Built-In Battery Charger
    Tri-Bar LED RV Tail Lights - Stop, Tail, Turn - Submersible - 33 Diodes
    Optronics LED Trailer License Plate Light with Bracket - Submersible - 5 Diodes - Clear Lens
    Peterson Low-Profile Oval Trailer Reflector - Aluminum Bezel - Amber
    Peterson Low-Profile Oval Trailer Reflector - Aluminum Bezel - Red
    Optronics Flexible LED Light Strip - Weatherproof - White
    TorkLift PowerArmor Solar Locking Battery Box - 6 and 12V Lithium Batteries - Powder Coated Aluminum
    Pintle Hook for 2" Hitches - 10,000 lbs
    So...if you don't see me much on the trails this year, you'll know why.
  7. Mar 12, 2021 at 8:57 AM
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    To many, but never done
    I do want to switch to having brakes on it, that weight doesn't help anything down hill.
    Im not sure what I'm going to do yet though, need to do some research.
    I have been wanting better bigger brakes on the truck also and I don't know if that will just fix the problem.
    BadDNA[QUOTED][OP] likes this.
  8. Mar 12, 2021 at 9:01 AM
    BadDNA
    Eammon
    Cabot, VT
    I went with electronic brakes since I have the brake controller in the truck already for the big camper. I was thinking of your comments about the trailer wanting to push you downhill and thought that with the electric brakes, I'd be able to independently engage them and almost use the trailer as an 'anchor' on hills if necessary.
    Skierrichy[QUOTED] likes this.
  9. Mar 12, 2021 at 9:21 AM
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    That does actually work too as long as your trailer has some weight to it, which yours will.
    I have watched a guy move to a different line by spinning his tires with the trailer break locked, it was pretty impressive.
    You will also be a better anchor too for winching people and you can set up a snatch block off your trailer.
  10. Mar 12, 2021 at 9:31 AM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Subbed, this looks like it will be awesome when complete!
    Skierrichy likes this.
  11. Mar 12, 2021 at 10:48 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    @BadDNA Hey Eammon, What were you going to do mounting an RTT on it? Were you planning on making uprights?
  12. Mar 12, 2021 at 11:00 AM
    BadDNA
    Eammon
    Cabot, VT
    mach1man001, ToyRyd04 and Skierrichy like this.
  13. Mar 12, 2021 at 11:13 AM
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    I have plans to actually raise it even higher for sleeping then drop back down to wheel.
    I actually have a lot of plans but can't get to anything on account of new job.
    I'm probably just going to have Down East do it all for me which takes the fun out of it but I have to much on my plate right now.
  14. Mar 12, 2021 at 11:23 AM
    BadDNA
    Eammon
    Cabot, VT
    I was thinking it'd be interesting to figure out a way to mount it on a set of extension posts, kind of like the roof on a pop-up camper, but then the complexity and more things to break stop me dead. I'm thinking just a mid-height lid like the one above should do it, but I want to get it on wheels and behind the truck before I start too far down that road. I also would like to keep the height and cog low for wheeling and visibility out the back on the road.
  15. Mar 12, 2021 at 11:23 AM
    #35
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    I do believe that having a solid lid on it is the way to go though, it does add more weight but it's nice keeping things dry and secure.
    @BadDNA I've been doing research on a kick ass way to heat your tent that is very safe and not going to cause a fire.
    I will let you know when I figure it out but basically you put the small unit in the trailer and cut a 2" hole in bottom of RTT.
    Forced hot air.
    You will need a dual battery system to run it though.
    More details to come.
    They call it a bunk heater for tractor trailers.
    Mine works awesome and there is virtually nothing that can catch fire.
    I've been researching Mr. Buddies and the lot and don't want anything to do with them on account of the dog.
  16. Mar 12, 2021 at 11:36 AM
    #36
    BadDNA
    Eammon
    Cabot, VT
    Dual batteries on the truck, or just a 'house' battery for the camper? Because I'm planning to have a 12v system in the trailer from the start for lighting, device charging, etc.
  17. Mar 12, 2021 at 11:39 AM
    #37
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    Yep I'm thinking marine grade batt for the trailer.
    crashngiggles likes this.
  18. Mar 12, 2021 at 11:45 AM
    #38
    BadDNA
    Eammon
    Cabot, VT
    I've been running a grey/blue-top Optima AGM in my travel trailer for 5 years and it's been bulletproof. I have 200W of solar on the roof of that rig. I'm planning to do the same with this minus the solar, or maybe a set of 2 Trojan 6V deep cycles in series. With much smaller electrical demand in this trailer, I think I can get away with the 10W solar built into the battery box I'm installing. I'm running a 7-pin plug to the truck, so it should charge the house battery while driving and then the solar panel gets a quick wipe when we park and let the sun keep it topped up.
  19. Mar 12, 2021 at 12:00 PM
    #39
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    That's awesome! I'd like to eventually run solar on the trailer but I know I'll break it if it's on the truck.
    Your trailer is going to come out awesome I can't wait until you finish.
    I'll finish by 2030 hopefully:burp:
  20. Mar 12, 2021 at 12:15 PM
    #40
    BadDNA
    Eammon
    Cabot, VT
    Yeah, I can't wait to get this rolling either. 2030 sounds plausible. I'm embarking down this path as somebody who's done a lot of wrenching on stuff over the years, but absolutely nothing in terms of fabrication. I've laid down exactly one bead of weld in my life, on a scrap piece in my buddies studio, and I expect to have to redo a lot of the early ones I make here before I'll consider it 'done'. I should clear out the spare bay in my garage soon and start setting it up to work on this though, that way I can do a little more practicing before setting to work on the camper itself.
