Badlands 12,000 lb winch $320 - "The Best Deal in Winching"
Discussion in 'Deals & Coupons' started by packfan88, Oct 27, 2011.
  1. Oct 27, 2011 at 3:59 PM
    packfan88
    packfan88 [OP] Very Nice !
    Acworth, GA
    Billy Lift, Cooper STT Pro, Westin Step bars, tinted, rain gaurds, EBC rotors hawk pads
    So harbor freight is carrying the BadLands winches. You can read about it in the Off Road magazine article.
    Basically its $399 and if you use the code DISC20 you get 20% off to make it a little over $300 ($320)
    Shipping and tax for me makes it $357.36. Im pretty sure you can print out a 20% off coupon and buy it in store too, but dont quote me on that one.
    Not too shabby a price for a decent winch. Like everything else at HF its not professional grade tools, but it will work.
    I mnot sure of their replacement policy on this item, but I would surely buy it if they offered it.
    winch
    article
    http://www.off-roadweb.com/tech/1112or_badlands_12000_pound_winch_best_deal_in_winching/index.html
    They also sell ATV winches wich are more then good enough under most circumstances.
    If anyonehas one post up a review
  2. Nov 23, 2011 at 7:27 AM
    upcountry
    upcountry Active Member
    Seattle
    07 Tacoma
    Picked one (12,000# Badland) up a few weeks ago. Got the 3 year full replacement option. $370 out the door. If it breaks within 3 years, they give me a new one. I might just try to break it at around year 2.9 to get a new one then.
    ARB Bullbar on it's way. Will have to see if it fits without too many mods/spacers. Will post update after install. Likely in the new year.
  3. Aug 7, 2012 at 9:45 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Any updates on this brand and model?
  4. Aug 8, 2012 at 7:14 AM
    upcountry
    Seattle
    07 Tacoma
    So far so good. See post #48 @ http://www.expeditionportal.com/for...-Weekend-Warrior-Build-Work-In-Progress/page5
    for pics of the winch install into the second gen Tacoma ARB Bull Bar. It just bolted right in. I had to use longer bolts, and had to re-drill the fairlead to match the hole pattern on the ARB Bullbar.
    Also see this link for info on how to Re-Clock the winch clutch handle (which you will need to do to install in the ARB bumper):
    http://forum.ih8mud.com/winching-recovery/603694-clocking-winch-instructions.html
    I have not had a lot of use yet, but have used to yank some trees out of the way, and have been through some excercises on state lands with the winch, tree straps, snatch blocks. Laugh if you want, but when I get stuck, I want to be ready to get un-stuck efficiently.
    I also had a good conversation about duty cycle with the Warn rep at an event I attended. Yes, the Warn has a better duty cycle rating but he did agree that by putting a masively over-rated capacity winch (12K when I only need 9K) and using the 12K for a far less load, the duty cycle should be twice as long and therefore outperforming a base model Warn 9K 9as far as duty cycle goes).
    So far, the quality of the winch seems good. The powder and assembly seems to be decent. The price is outright awesome.
    I did move the solenoid box into the engine bay to protect it from moisture ( I live in the PNW and we get a lot of moisture). See post #75 in the above linked build thread on Expo. To move the box, I had to extend the terminal cables with 2 gauge wire ($$$).
    The weakest link on the winch seems to be the Solenoid box, which is of notably lower quality than the actual winch.
    Time will tell.
  5. Aug 26, 2012 at 10:34 PM
    xpocad
    xpocad Well-Known Member
    Bryan
    San Benito Tx
    2012 DBL CAB TRD Sport 4x4
    3" Revtech Leveling kit 17" XD Addict Rims with -12 offset White Led dome lit interior Avid Light Bar 21" Blitz Pro Led Bar
    will it work with the under cover winch plate
  6. Apr 10, 2013 at 5:31 AM
    shutterbug
    shutterbug Well-Known Member
    Cameron
    Downey, ID
    06 Blue Tacoma
    Trd intake, flowmaster exhaust, URD Maf calibrator, 3inch lift, Firestone Ride-rite airbags, Raceline 16" wheels, Fibeglass shell, carpeted bench kit, billet grill, Pioneer AVH1400DVD, Kenwood 150 watt amp, Kenwood 12" subwoofers, Access steering wheel controls
    I'm going to try it here this spring... just need to get the winch and get fabricating.
  7. Jan 10, 2014 at 2:15 PM
    Li0nel1234
    Li0nel1234 Well-Known Member
    Lionel
    Denver
    14 TRD OR DCSB SSM
    HFT is having a "sidewalk" sale this weekend. This winch is 100 bucks off... If you've been on the fence... now's the time...
  8. Jan 10, 2014 at 11:32 PM
    cmj
    cmj Well-Known Member
    Tucson
    98 Tacoma 4x4
    So they have a few 9000 lb winches. The specs are a little different between them. I'm guessing that they bump up the specs every now and then.
    There's a 9000lb winch (#61325) thats at 259.99 on sale (web) and a 20% code works on it which brings it to $232 after tax and shipping.
  9. Jan 10, 2014 at 11:49 PM
    cmj
    Tucson
    98 Tacoma 4x4
    Just found a 25% off code.. 218 w/tax and shipping. It does appear to have less horsepower and cable length than the other item #. 4.6hp vs 5.5 and 65ft vs 85 ft.
    Here's the code if anyone's interested 26174570
  10. Feb 20, 2014 at 10:41 AM
    So Many Roads
    So Many Roads Member
    looks like a good option, thanks for the heads up
  11. Feb 20, 2014 at 11:33 AM
    cmj
    Tucson
    98 Tacoma 4x4
    FYI, warn rebates are going on right now. I ended up buying an m8000 for <$500 shipped.
